Volume Between Two Surfaces Defined by Boundary Values
  • Thread starter Thread starter Inertigratus
    Boundary Integral
Inertigratus
Find the volume between z = x2 + y2 and z = 2 - (x2 + y2).
if r2 = x2 + y2
then the lower part of the volume is defined by:
r2 \leq z \leq 2 - r2
and: 0 \leq r \leq 1
the upper part by:
2 - r2 \leq z \leq r2
and: 1 \leq r \leq \sqrt{2}
\int\int\int1 dxdydz, after switching to polar coordinates I get
\int\int\intr drd\Thetadz
Theta varies from 0 to 2 pi. That leaves me with taking the integral with respect to r and z.
I do it for z first, then finally for r. Then add the two volumes. But it's wrong.
Any ideas?
those 2 curves intersect at x=1 and the plane z=1 , I would break it up into 2 parts and go from z=1 to the top of the paraboloid and then do the second part from the bottom paraboloid to the plane z=1 , because if you don't do that your radius is not always going to the same thing. Actually now that I look at it you kinda did that.
Hi Inertigratus! :smile:
(have a square-root: √ and a pi: π and a ≤ :wink:)
… the lower part of the volume is defined by:
nooo :redface:, that's the whole of the volume :wink:
Hehe, now you got me confused... :P
It's the whole volume?
I split it, because when r = 1, then 1 ≤ z ≤ 1, if you go up to r = √(2) then 2 ≤ z ≤ 0, which looks a bit weird since 0 is not greater than 2...
So lower part from 0 ≤ r ≤ 1, upper part from 1 ≤ r ≤ √(2)
Is that wrong? :P
I guess the question is: what do you mean by the "lower part"? What you have, 2- r^2\le z\le r^2, is incorrect because the paraboloid z= 2- r^2 is above the parabolid z= r^2.
It's confusing...
Because, I know that when r = 0, then 2−r2 is obviously larger than r2.
What's confusing me is that when r is increasing, and reaches r2 = 2, then the inequality doesn't make any sense. 2 ≤ z ≤ 0 makes no sense.
So I was thinking as I said in my first post, that I would have to split it into volumes.
Above z = 1 and below z = 1.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
