Does Monotonicity and Boundedness Imply Bounded Variation?
JG89
A sequence b_n is said to be of bounded variation if the series \sum_{n=1}^{\infty} |b_{n+1} - b_n| converges.
Prove that if b_n is of bounded variation, then the sequence b_n converges.
If b_n is of bounded variation, then for all epsilon > 0, \sum_{v=n}^m |b_{n+1} - b_n| = |b_{n+1} - b_n| + |b_{n+2} - b_{n+1}| + ... + |b_m - b_{m-1}| + |b_{m+1} - b_m| < \epsilon provided that n and m are sufficiently large.
Notice that by the triangle inequality |b_{n+1} - b_n + b_{n+2} - b_{n+1} + ... + b_m - b_{m-1} + b_{m+1} - b_m| = |-b_n + b_{m+1}| = |b_n - b_{m+1}| \le |b_{n+1} - b_n| + |b_{n+2} - b_{n+1}| + ... + |b_m - b_{m-1}| + |b_{m+1} - b_m| < \epsilon and so the sequence b_n is Cauchy, meaning it must converge. QED
I have another question regarding bounded variations that is kind of similar to this question. The proof is short and I don't want to clog up the forum with multiple threads on the same topic, so I will post is in here:
Question: If a sequence b_n is bounded and monotonic, prove that it is of bounded variation.
Proof:
In this proof we will assume the sequence is monotonic increasing -- the proof can easily be adapted to prove the same result for the sequence being monotonic decreasing.
If b_n is bounded then there exists a fixed value, say B, such that |b_n| <= B for all n. Now,
\sum_{v=1}^n |b_{n+1} - b_n| = |b_2 - b_1| + |b_3 - b_2| + |b_4 - b_3| + ... + |b_{n+1} - b_n| . Now since b_n is increasing, b_{n+1} - b_n >= 0, and so we can remove all of the absolute value signs. We now have \sum_{v=1}^n |b_{n+1} - b_n| = |b_2 - b_1| + |b_3 - b_2| + |b_4 - b_3| + ... + |b_{n+1} - b_n| = b_2 - b_1 + b_3 - b_2 + ... + b_{n+1} - b_n = -b_1 + b_{n+1} \le b_1 + b_{n+1} \le 2B.
Notice that the bound we've obtained for the n'th partial sum is a fixed value independent of n, and so 0 \le \sum_{v=1}^{\infty} |b_{n+1} - b_n| \le 2B. The n'th partial sum is bounded and since each term is positive, the sequence of partial sums is increasing. Thus the sum converges.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
