What is the acceleration and time for a block on an inclined plane?
The discussion centers on calculating the acceleration and time for a block sliding down an inclined plane. The user attempts to apply Newton's second law and kinematic equations but struggles with the correct interpretation of the problem, particularly regarding the block's initial velocity and distance. They calculate forces acting on the block, resulting in an acceleration of 1.5 m/s² down the plane. However, confusion arises over the distance traveled and the initial conditions given in the problem. Clarification on these points is needed to accurately determine the time it takes for the block to slide down the incline.
rumblef1sh
I am stuck on a problem from the 5 Steps to a 5: AP Physics B&C book and would really appreciate anyone's help.
Determine (a) the acceleration of the block down the plane and (b) the time for the block to slide to the bottom of the plane.
http://02.edu-cdn.com/files/static/mcgrawhillprof/9780071623209/INCLINED_PLANES_08.GIF
F=ma
F, gravity = mg
F, friction = umg
Kinematic equation ?
Fx, up the plane = mgsin25 + umgcos25 = 204 N
a = F/m = 204/30 = 6.8 m/s^2
Fx, down the plane = mgsin25 - umgcos25 = 44 N
a = F/m = 44/30 = 1.5 m/s^2
I tried using x = Vot + 1/2 at^2 (x = 20 m, Vo = 3m/s) and v = Vo + at (v = 0, Vo = 3 m/s) to solve for time, but my answers were way off on both attempts.
If the question says the mass is going 3 m/s up the plane, and the a) part asks for the acceleration DOWN the plane this means that x != 20, but it is going to be 20 added to the distance traveled by the mass until it changes direction. I hope that helped.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
