Breaking Point for a Copper Wire
The discussion focuses on determining the maximum load a copper wire can support before breaking, given its dimensions and material properties. The elastic limit of copper is 2.9 x 10^8 Pa, and the tensile strength is 4.3 x 10^8 Pa. Participants emphasize the importance of understanding stress and strain, noting that the wire will return to its original length unless the elastic limit is exceeded. To find the breaking point, one must equate the stress in the wire to the elastic limit and consider the wire's cross-sectional area. The conversation highlights the need for proper unit conversions and definitions of stress to solve the problem effectively.
Ike
What is the maximum load that could be suspended from a copper wire of length 1.9 m and radius 1.2 mm without breaking the wire? Copper has an elastic limit of 2.9 x 10^8 Pa and a tensile strength of 4.3 x 10^8 Pa. Give your answer in Newtons (N).
Any thoughts? I'm completely lost.
Well you may want to start by converting the Pascals to its other SI units (part of it is in Newtons...). That should make it a bit more apparent.
My main problem here is this...
When a wire is stretched, it will return to it's original length if the weight is removed. This is true, unless the elastic limit has been reached, in which case the wire will be permanently stretched. Before this point, the proportional limit is met, in which the tensile strain and the tensile stress are no longer proportional. Further beyond the elastic limit is the point of ultimate strength. I assume this is the same as tensile strength. Further beyond this point is the breaking point.
I have no idea how to derive the breaking point at all, nor how to find the maximum weight before that point for that matter.
Oh yes, and one Pascal is the same as one Newton per square meter.
1 Pa = 1 N/m^2
Since you are only given the elastic limit (yield point) the problem assumes that the onset of yielding will be the breaking point.
You should start looking at what the definition of stress is. If you set the stress in the wire equal to the elastic limit...
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
