Bridge and center-trapped full wave rectifiers
  • Thread starter Thread starter M11
    Bridge Wave
The output DC voltage of a center-tapped rectifier is half that of a bridge rectifier when using the same transformer primary-to-secondary ratio. This is because the center-tapped configuration only rectifies half of the total secondary voltage during each half cycle, while the bridge rectifier utilizes the full secondary voltage for rectification in both half cycles. If a center-tapped rectifier had a transformer with a secondary voltage twice that of the bridge rectifier, the output would still be half, excluding diode voltage drops. The difference in output voltage is fundamentally due to the number of diodes and the voltage utilized in each configuration. Understanding these principles is crucial for designing efficient rectifier circuits.
M11
Why the output DC voltage of the center trapped rectifier is half that of a bridge rectifier??
If you mean for the same transformer primary-to-secondary ratio but with the center tap used in one case (with 2 diodes) and with the the total winding used in the other (with 4 diodes in a bridge configuration) - then yes that's true. In the first case only half the total secondary voltage is rectified on each half cycle whereas in the latter case the full secondary voltage is rectified on each half cycle of the mains waveform. If the CT case had a different transformer with a total secondary voltage twice that of the other, then the result would be the same - ignoring the diode voltage drops.
18K
