Brightness detected based on direction of travel relative to source
wsellers
I don’t see that this question has been asked before and I am hoping the generous moderators of this forum will be able to answer it.
Suppose you have the “standard” situation with the man M on the embankment and the woman W in the center of the moving train car. (The train has lots of windows enabling M to see in.) W strikes a match (it’s a special kind of match that has a constant luminosity, L). The distance between W (and the match) and the front of the car is D1; the distance between W and the back of the car is D2. Since we assume W is in the exact middle, D1=D2.
At each end of the car is a brightness detector with a digital LCD readout. Brightness is equal to L/4[pi]r, I believe, where L is luminosity and r is the distance from the light source to the detector. The distance that the light travels from the match to the front detector is r1; the distance that the light travels from the match to the rear detector is r2.
Because the train is moving toward the front, r1 > r2. This should mean that the rear detector measures a level of brightness that is greater than that measured by the front detector. Thus the rear detector would display a number that is greater than the number displayed by the front detector.
Wouldn’t M and W see the same numbers? In the same train car going in the opposite direction, wouldn’t the rear detector display a number that is less than the number displayed by the front detector?
You forgot the http://www.anu.edu.au/Physics/Searle/Obsolete/Seminar.html" (I found this site independently :wink: ).
Quick explanation: There are many effects you have to consider, all of which conspire to make the Lorentz Transformations valid. However, if you look at it differently: The LT are indeed valid (or, at least, self-consistent), and all those effects are simply derived from it. So it is no miracle that all works out self-consistently.
Energy is a frame-variant quantity so luminosity (energy/time) and brightness (luminosity/area) are also frame variant. A detector moving away from a source will generally detect lower energy than one moving towards a source as the Doppler red-shift lowers the energy of the detected photons, but does not change the number of photons.
Thanks very much! I wasn't aware of the headlight effect.
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
Thread 'Dirac's integral for the energy-momentum of the gravitational field'
See Dirac's brief treatment of the energy-momentum pseudo-tensor in the attached picture. Dirac is presumably integrating eq. (31.2) over the 4D "hypercylinder" defined by ##T_1 \le x^0 \le T_2## and ##\mathbf{|x|} \le R##, where ##R## is sufficiently large to include all the matter-energy fields in the system. Then \begin{align} 0 &= \int_V \left[ ({t_\mu}^\nu + T_\mu^\nu)\sqrt{-g}\, \right]_{,\nu} d^4 x = \int_{\partial V} ({t_\mu}^\nu + T_\mu^\nu)\sqrt{-g} \, dS_\nu \nonumber\\ &= \left(...
Abstract The gravitational-wave signal GW250114 was observed by the two LIGO detectors with a network matched-filter signal-to-noise ratio of 80. The signal was emitted by the coalescence of two black holes with near-equal masses ## m_1=33.6_{-0.8}^{+1.2} M_{⊙} ## and ## m_2=32.2_{-1. 3}^{+0.8} M_{⊙}##, and small spins ##\chi_{1,2}\leq 0.26 ## (90% credibility) and negligible eccentricity ##e⁢\leq 0.03.## Postmerger data excluding the peak region are consistent with the dominant quadrupolar...
