Buck Converter with USB-C output
2 replies · 2K views
gumby4231
TL;DR
I'm seeing what options are available to power my single board computer.
I have a https://www.lattepanda.com/products/lattepanda-delta-432-with-win10-pro-activated.html single-board computer. For my project, I'd like to power it from a 12V tractor battery if I can. I also have the option of powering it via the JST ph2.0 4P 12V DC connector. I discuss this option with some from the Lattepanda forum here. I'd however like to explore all of my options. Thus I have been looking into the USB-C option. The problem is there doesn't seem to be many regulators with USB-C connectivity that meet it's power requirements (15V 3A).
Testing has shown that the board consumes much less power than this, these are simply the supply Lattepanda officially recommends.
I have found https://www.renesas.com/us/en/products/power-management/battery-management/multiple-cell-battery-chargers/device/ISL95338.html#documents, but it's industrial with a high minimum order quantity(250). It's got a lot of documentation there and the technical language is pretty dense for me as a beginner, so its quite possible I missed some stuff.
I was also considering using a Buck converter with USB output, and then use a USB A to USB-C adapter. This is the best combination I could find (Buck Converter & Adapter). As you'll see, they don't seem to meet my power demands. The buck converter will do 30W at 5V, while the adapter is only capable 2.4A @ 5V.
Does anyone have any recommendations?
gumby4231 said:
Summary:: I'm seeing what options are available to power my single board computer.
Sorry, I'm no USB expert, but your post is confusing to me.
AFAIK, "USB-C" specifies the connector mechanicals and the data speed, but does not necessarily specify high current capability (I could be wrong about that).
https://www.pcmag.com/how-to/what-is-usb-c-an-explainer
USB 2.0 versus USB 3.0 may specify different current levels (I'm also not sure about that), but I don't think any USB specification will supply the power levels that it sounds like you are wanting at 45 Watts.
Oops, I see that @Baluncore is faster than I am -- I was about to suggest the same thing about using the 12V directly, but maybe with a little noise filtering in addition to the protection recommendations that he posted.
