Bucket elevator drawing high power
A bucket elevator used for conveying cement mill feed is experiencing abnormally high current draw, reaching up to 120 kW when loaded, compared to the normal 80 kW. Despite replacing deformed buckets, the issue persists, suggesting potential underlying problems. Possible causes include motor or gearbox damage, lubrication failure, or changes in material density. The discussion emphasizes the importance of inspecting mechanical components and considering wear and tear on the motor. A systematic checklist approach is recommended to identify and resolve the issue effectively.
oriehi
A bucket elevator for conveying solid material (cement mill feed of 30mm~2.5mm) draws an abnormally high current when loaded. some buckets where discovered deformed. The deformed buckets where changed, but the elevator still took high kilowatt on start up. Please what could be the cause.
Welcome to PF;
Lots of things could be doing that - maybe the motor is a bit broken?
It's not clear why you'd expect a deformed bucket to change the load on the motor.
Is the higher than spec current drawn only at the startup, and then it settles down, or is it like that all the time it's running? (Or very high at startup but also higher than spec while running?)
The bucket normally draws high load on start up, but stabilizes in few seconds on normal operations with no load (ie about 12kw). but when loaded, the power drawn goes as high as 120kw, as against about 80kw, on normal operating conditions.
We suspected restrictions, but on inspection no restriction was discovered.
Some thoughts:
  • motor bearing damage or failure
  • motor winding damage or failure from overheating
  • gearbox bearing damage or failure
  • gearbox lubrication failure
  • bent or damage chain links
  • carrier shaft bearing damage or failure
  • bent or damaged carrier shafts
  • material change (is heavier per unit volume)
The increased current you get is due to an increased load. It could be an increase in torque from many causes.
Yeah, that's how I was imagining things ... and I also imagine that something gumming up the works is the most common cause for unusually high loading on the motor.
In the absence of external mechanical drag, you have to suspect the motor is wearing out.
What tygerdawg said ... you just have to work through a checklist.
Thanks a lot guys, we'll check it out
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
