TriflingTroy said:
Anyway they will be individual dipoles with different frequencies that will arranged horizontally. There will also only be one up at a time.
Hi Ethan OK
OK I did misunderstand what you initially said
you haven't said what frequencies you are using or if this is for transmitting, receiving or both ??
here's a pic of an HF freq dipole feed, for 30MHZ
the gap between those ends will be around 4 - 5 cm ( ~ 2 inches)
This gap will get smaller as you go up in freq,
at VHF say 144MHz ham band they will be around 3 cm
at UHF say 432MHz ham band they will be around 2 cm
at SHF say 1296MHz ham band they will be around 1 cm
the distance isn't absolutely critical and as long as you are close to those measurements you will be OK
its more critical for transmitting than receiving ( the gap distance will affect the impedance of the feedpoint)
TriflingTroy said:
The parallel wires will be for the feedline, and what I was wondering on that aspect is the difference of Coaxial Wire and twin lead wire.
personally I wouldn't use parallel wire feedlines just too difficult a job mounting them on mast etc and you will need BALUNs as they won't have the correct impedance. A straight dipole has an impedance of 75 Ohms so would normally require a 75 Ohm impedance feedline, say RG59 coax ( if for transmitting, for lower powers (up to ~ 100W) RG6 for higher powers ... several 100 W) tho you can get away with using 50 Ohm coax say RG58 or RG8, RG213.
EDIT addition, you want to be building 1/2 wave dipoles ... each side will be 1/4 wavelength longdoes that help ?
