Building a Simple metal detector circuit
A user is attempting to build a simple metal detector that responds to a steel pendulum using an RL circuit with a copper coil, but finds the voltage drop across the resistor minimal. They then tried an RLC circuit in resonance, hoping for a more significant change in impedance, but this also did not yield satisfactory results. Suggestions include using a design with two oscillators at around 250KHz, where one is a reference oscillator and the other is an LC oscillator that detects metal by frequency changes. The importance of using a stable power supply for the 4046 phase lock loop is emphasized for better sensitivity. Overall, the discussion revolves around improving metal detection circuit designs and exploring alternative methods.
pashnoy
Hi guys, I am new at this so sorry if i get the format wrong.
Im trying to build a basic metal detector that will respond when a steel pendulum passes nearby. A simple response is all that is needed right now.
I thought of this:
Building a RL circuit with a copper coil air core. placing a m/meter over the resistor and reading that its (the resistors) voltage drop should lower as the inductance of the coil changes with the pendulum passing near to it. (and the flux having a low impedance to pass through )
this didnt work well enough as the change over the resistor drop was minimal!
(the source was set at 10Vp-p and a high frequency)
I then thought to make an RLC circuit in resonance and using the same logic only that the drop should change dramatically (what i need!) with a slight change in impedance.
this too did not yield a clear enough result.
any tips for improving this design or a new simple design all together?
thanx
A pretty sensitive metal detector topology is having two oscillators at around 250KHz. One oscillator is a reference oscillator and it's shielded. The other one is an LC oscillator like the Colpitts with the inductor being the main pick up coil used to detect metal.
When a metal is brought close, the LC oscillator will slightly change frequency. Then subtract the reference oscillator frequency from the LC oscillator frequency using a mixer. The difference will be in audio range which can be heard as a pitch or tone.
I (sorta) invented a little metal detector -- more likely I stole most of it from some unspecified online source -- for my robots using a 5" diameter 40 turn coil that calcs out to being about 50uH. The coil makes an oscillator osculate and that is feed into a 4046 phase lock loop which tracks the slight changes in frequency caused by nearby metal thingies and puts out a voltage that changes with frequency:
http://www.etantdonnes.com/ROBOCAR/doc/hardware/RoboOther_sch.png"
YMMV on sensitivity and such, but it's a place to start. I found that the 4046 is _extremely_ sensitive to supply voltage, so add a good regulator to the power -- the built-in Zener diode is just not up to the task when the supply is near the cutoff.
I thought of this:
thanx
Can you use optical detection instead?
I am restained to using a copper wire coil in the detection of the metal
if you're willing to use 1970-ish technology, try the circuit on page 68-69 of this old book (PDF page 70).
Back before microcomputers I built one and it worked as well as store bought detectors of the day.
http://bitsavers.trailing-edge.com/pdf/signetics/_dataBooks/1972_Signetics_PLL_Applications.pdf
the book is an excellent introduction to phase locked loops. I'd recommend you download and print a copy.
old jim
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
