Finding 6V/12V Taillight/Brake Light Bulbs in Milwaukee
  • Thread starter Thread starter Shawnzyoo
    Light
Finding 6V and 12V taillight and brake light bulbs in Milwaukee is challenging, as local auto stores lack the necessary wattage specifications. The discussion clarifies that the CP (candle power) rating indicates brightness, with a relationship between voltage and power output. For a 1978 Puchs moped, specific bulb types are needed, and resources like MopedWarehouse.com and MopedGuru.com are recommended for sourcing these bulbs. The conversation also explains that doubling the voltage increases power output significantly, which is crucial for matching the right bulbs. Overall, participants share links and insights to help locate the appropriate lighting solutions for vintage mopeds.
Shawnzyoo
so i am trying to find taillight/ brake light bulbs
i need a 6v 10 w (12 v 20 w)
and a 6 v 5 w (12 v 10 w)
and autostores are worthless in milwaukee
none of the carriers have the Wattage listed
they have the CP
i amnot sure what the CP is on these bulbs?
is there a direct relationship to figure it out?
thanks
--shawn
I'm not sure why you would spec a car light bulb at 6V, but here's a helpful website with car light bulb info. Taillights are usually 2057. Does your old bulb have the number 2057 anywhere on it?
http://www.theherd.com/articles/bulbs.html
sorry its not for a car but for a 1978 Puchs moped
hence only the 6 volts
Yikes! Okay, back to google:
website with older scooter bulbs for sale:
http://www.dynamo.mz-b.de/lights/lampen.htm
discussion forum mention of scooter bulbs:
http://www.mopedriders.org/viewtopic.php?t=804&highlight=
MopedWarehouse.com and MopedGuru.com (Tech Support questions):
http://www.mopedwarehouse.com/
light bulbs at MopedWarehouse.com:
http://mopedwarehouse.com/catalog/default.php/cPath/38_40
That last link looks the most promising. Good luck! -Mike-
CP = candle power, one filament is going to produce more than twice as bright a light when the brake light is applied compared to the running light.
And if you double the voltage, you get 4x the power, minus the increased resistance from increased temperature of the filament, so its ends up at pretty much 3x the power for double the voltage. So make sure you account for this if the CP is given for 12V instead of 6V CP.
For what you looking for, a close match would be 2-3 CP and then 5-6 CP for the two filaments a 6V (or 9CP/18CP at 12V), this is based on a guess of roughly 6Lumen/W and 12Lumen=1CP which should be close enough for this application.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
