Why Do We Divide Change in Volume by Original Volume in Bulk Modulus Formula?
In summary, bulk modulus is a measure of the compression of a material. It is important because it is a property that is independent of the size of the sample.
AakashPandita
157
bulk modulus = Δp/ΔV/V
Why do we need to divide change in volume by the original volume?
why is it important?
Say you have a spring with spring constant k that is one inch tall with no weight on it. Now say you put on top the spring a mass which compresses the spring 1/10 an inch. Now stack two such springs on top of each other and place the same mass on top of the stacked springs. It should not be too hard to convince yourself that the two springs together will now compress by 2/10 an inch. The compressive properties of the springs, k, has not changed but with more springs you get more movement. Compressive material acts like the springs, more springs stacked on top of one another you get more movement for a given force.
If we apply compressive forces to some object we want to know how much it will change shape but that depends on the size and its properties.
Does this make sense or help?
Because if we used just Δp/ΔV, the bulk modulus would depend on the size of the sample. We want a quantity that is independent of the sample size.
say i have 2 iron blocks. 1 is a small block and other is huge.
I need to decrease each of their volumes by 10 m^3.
would the force required in each case be the same or not?
No, it would not.
What if the small block is 1 m^3 and the large one is 100 m^3?
Assume you find the force you need to decrease the volume of the large one by 1 m^3.
Will the same force decrease the volume of the first one by 10m^3? Will any force be able to do this?
Can you see what kind of problems will arise trying to define a property in terms of absolute values? Not that is not possible.
Absolute value of volume change is not a property of the material but of the specific sample.
this is interesting! thanks.
1. What is the bulk modulus formula used for?
The bulk modulus formula is used to calculate the amount of resistance a material has to compression under a given amount of pressure. It is commonly used in engineering and materials science to determine the elasticity and strength of a material.
2. How is the bulk modulus formula derived?
The bulk modulus formula is derived from Hooke's Law, which states that the stress on a material is directly proportional to the strain applied to it. By rearranging this equation and incorporating the concept of bulk modulus, we can calculate the change in volume of a material under a given pressure.
3. What are the units of measurement for bulk modulus?
The units of measurement for bulk modulus are typically given in pascals (Pa) or newtons per square meter (N/m^2). However, depending on the context, it can also be expressed in other units such as pounds per square inch (psi) or gigapascals (GPa).
4. How is the bulk modulus formula different from the Young's modulus formula?
The bulk modulus formula measures the resistance to compression, while the Young's modulus formula measures the resistance to stretching or tension. In other words, bulk modulus is a measure of the material's response to pressure, while Young's modulus is a measure of its response to tension.
5. Can the bulk modulus formula be used for all types of materials?
No, the bulk modulus formula is specifically designed for homogeneous, isotropic materials. It is not applicable for materials that are highly anisotropic or have complex structures, such as biological tissues. Additionally, the formula assumes that the material is elastic and follows Hooke's Law, so it may not be accurate for materials that exhibit non-linear behavior under pressure.
  • Other Physics Topics
  • Materials and Chemical Engineering
  • Mechanical Engineering
  • Classical Physics
  • Classical Physics
