Bull charging and you charge the bull
  • Thread starter Thread starter TheWonderer1
    Charge Charging
The discussion centers on the physics of a bull charging at a human versus the human charging at the bull, focusing on momentum and kinetic energy. It is established that the impact force experienced by the human is greater when the bull charges due to the combined velocities, resulting in higher acceleration and damage. The frame of reference is clarified as irrelevant to the physics of the collision, emphasizing that the energy and momentum experienced by the human are what matter. Participants also share personal anecdotes about encounters with bulls, highlighting the unpredictability of such situations. Ultimately, standing one's ground against a charging bull is deemed a poor choice, as the impact would be significantly more severe.
TheWonderer1
Would you be better off standing your ground? I don't actually know how massive a bull is but let's say about 1,700 kg. It's coming at you with a velocity of 16 m/s. You got a human who is a decent 93 kg and runs in the opposite direction at 12.517 m/s (he's an olympian 100m runner). Would this decrease the impact rather? I'm thinking about conservation of momentum.
The total momentum of the system changes from about 25,600 to 24,600 (compared to standing). It's not that significantly different if he stood there with no momentum but I'm just thinking a bit.
Apologies, I didn't think about kinetic energy and relative speed.
It isn't the momentum or KE with respect to Earth that matters, it is with respect to you that matters.
One way to think of it is this: by your argument crashing your car into an identical, but stationary, car should trash your car but a head-on collision at speed shouldn't even scratch your bumpers. As Russ says, it's the momentum and energy in your rest frame that matters in determining how much the initial impact will hurt. The Earth frame only becomes important in thinking about how much hitting the ground will hurt.
What if the bull stood still in indifference, and the human ran at it?
What would you then say about the impact?
Are we saying that the choice of frame of reference is a moooot point? :wink:
I think to answer the question it would hurt far less to run at a bull that was standing still because there is no momentum coming at you. However, it would still hurt.
I'm not sure what the reference point bit is getting at since you just mention that it matters only in your own reference point.
What if the bull was charging at you from the east? The Earth is rotating eastward and by a non-rotating standard there is no momentum coming at you at all.
Ok but you would still feel that bull pretty badly.
Was I correct in my assumption that you running at bull would hurt less than the opposite?
Fair enough - I didn't say that well. Reference frame doesn't matter to the physics. But it's easier to solve particular problems in some frame, and in this case your rest frame has helpful properties. Particularly because you initially chose to work in it for the first half of the problem statement.
No.
jbriggs444 said:
No.
Why not? The overall momentum experienced by you would be less and same as your KE. I understand it's about what you experience so that's the involvement.
TheWonderer1 said:
Why not?
Because both are descriptions of the exact same collision. The movement (or not) of the Earth beneath the feet of the person or of the bull is irrelevant.
I don't see that since there are different amounts of momentum and energy involved.
Are we comparing the same scenario? If you had a bull charging at you vs. if you charged the bull?
Your change in velocity and the associated acceleration and force would be greater if you run toward the bull.
Ok there is some important aspect I'm missing. The frame of reference stuff changed my understanding and I get that pretty well. I see why the Earth moving meaning no momentum would be still a hurtful scenario. However, you charging at the bull who is at rest seems different completely. This is still stumping me as I see the bull sitting there in my head. I run at it and the bull feels very little. I feel my momentum bounce me backwards. However, if that bull decided to charge me, I would bounce much further than if I charged or stayed still hurting me a lot more. I'm going to test it :)
Force causes damage. F=MA. Acceleration is what counts. Whether you run into the bull at speed v or the bull runs into you at speed v doesn't matter. The acceleration is the same so the damage is the same. If you and the bull are running toward each other, that increases the velocity of the collision and increases the acceleration (=> force => damage) that you would suffer.
I would take one step to the side just before estimated time of impact or throw a red rag on the ground and run up a tree.
Fun fact: bulls run faster up hills than down hills.
Likes OCR
Ok just to get to the meat of what you are saying, running at a bull and the bull runs at you would mean greater acceleration than the bull at speed v OR the human at speed v. Therefore, you get hurt much worse.
Also consider the weight of the human, a big guy will get more impact from the same bull than a lighter guy.
Let's do a simple example with simple numbers. You have mass 100kg and the bull 1000kg. You can both run at 10m/s.
1. You are stationary and the bull runs at you at 10m/s. You get stuck on its horns. What is the velocity of the bull+you just after the collision? What is your kinetic energy before and after the collision?
2. The bull is stationary and you run at it at 10m/s. You get stuck on its horns. What is the velocity of the bull+you just after the collision? What is your kinetic energy before and after the collision?
It's the same 1100kg mass and the 20 m/s. I think that means you have like 440,000 Joules. That correct, I think the mass are combined because they are attached by the horns?
No. Where are you getting 20m/s from?
In the first case, momentum was Mv=1000×10=10,000kg m/s before the collision. Conservation of momentum means that Mv=(m+M)u, so u=9.1m/s for the stuck-together-man-and-bull.
In the second case, mv=100×(-10)=-1,000kg m/s before the collision. Conservation of momentum means that mv=(M+m)u, so this time u=-0.9m/s.
You answer the second part of the questions. What's your kinetic energy before and after the collision?
I think part of the problem is that, according to what I'm getting from you here, you are still thinking in terms of a reference frame of the Earth. Hence why you're saying "bounce much further", you're still thinking in terms of the physics with respect to the ground. You need to forget the ground is even there. Heck, I'd even replace you and the bull with two balls floating in space or some other scenario where all references to the Earth are gone. Then once you understand the physics behind collisions you can apply it to you and a bull.
891 J and 91,000 J and I believe it's the same kinetic energy before and after.
If your velocity changed, how can your kinetic energy be the same before and after?
Are we assuming the bull maintains a constant velocity , highly unlikely.
This problem is so unrealistic in the context of a bull its useless, stick with hard balls in space.
Likes OCR
Was in the middle of fixing it :)
Ok before for the bull charging: 1/2mv which means that I think that is 50,000J. Also, I think the change is 45,500 J rather than what I said.
Other case: 5,000 J, same here it's 445.5 J.
I kind of rushed the calculation. It might be off
If the bull is charging then you are stationary and your kinetic energy is zero.
That's true.
  • #31
So other than that is my math basically correct? If this is the case, then the bull charging you would give you a lot more energy.
  • #32
I'm sorry - I asked slightly the wrong question above. It's been a long day. The question is, what is the total kinetic energy of the system before and after the collision in each of the two frames? Where did the energy go? Having thought about that, do you notice anything about the change in each case?
  • #33
I'm a bit confused myself and I feel like at this point anything I say will stem from that. I know this is awkward but could you just explain it? I feel that this confusion might continue otherwise.
I think they both change the same amount from after and before. It's like 4,500J, the difference. It's not the same afterwards though and I think the bull charging has a much higher kinetic energy on the human. I guess energy is lost by heat. I am just thinking about how the bull has energy as it charges.
  • #34
houlahound said:
I would take one step to the side just before estimated time of impact...
My brother actually did try that, and this is what happened...
It's unusual, but one of our bulls did charge him... he was aware of the fact, and knew he couldn't out run the bull, but, he thought he could use his hand to help push himself away from the bulls head, and actually, this is a fairly common technique used when working with cattle... not necessarily charging bulls, though.
My brother was standing just slightly to one side, and as the bull was about to make contact, my brother extended his hand to push on the bulls head...
The bull, almost instantly, lowered and turned it's head... my brother's hand missed the bulls head, the bull's head caught my brother about mid-body, and lifting it's head, flipped my brother into the air, then caught him on the way down... again, lifting it's head... this time, though, the bull's head caught my brother's right hip, fracturing it.
He was very lucky that the bull just walked away... sometimes they don't...!
This bull isn't "charging" but you can, more or less, understand the... technique used.
Oh, and BTW, we raise naturally polled Angus cattle... they don't have horns.
I think my brother would say... "No!" .. :oldwink:
Likes jedishrfu
  • #35
It helps if you circle a bit, bulls commit pretty well to a charge and usually shut their eyes just before impact unlike cows who are way more dangerous.cows stand up in front of you with their eyes open and try trip you by kicking forward with their front feet and rake with their horns.
Polls are more dangerous and can usually fight with more skill as you found out.
I was involved with a few restocking programs when some big holdings got taken over by national parks.
Lots of helicopters, portable pens, motorbikes, horses, dogs and chaos.
Likes OCR
  • #36
Hey guys, I'm appreciative the answers thus far but please be aware that involving bulls and humans or a more massive ball hitting a lighter ball is the same to me. Let's go forward with a bull and human without the Earth involved. This is an unrealistic scenario and that's the parameters. From what I have gathered so far, the momentum and energy given as an observer or the Earth perspective doesn't matter. It's only the energy and momentum that's coming at the person. Now, I see that Ibix has tried to explain this to me using a word problem. I believe that the end of this word problem as I currently understand it is that the Bull charging the human scenario means that the human has more kinetic energy at the end of the collision. Additionally, the human charging the bull has less kinetic energy comparatively. Furthermore, the total energy DIFFERENCE from before and after is exactly the same between the two different scenarios. I don't know where the rest of the energy goes.
I do understand how the charging bull AND human charging scenario would mean more damage. I think this was shown very well by FactChecker.
I'm confused on the fact that there is the kinetic energy difference between the scenarios (after collision). Although, people are saying the charging bull or charging human scenarios are exactly the same with exactly the same result. If someone can take Ibix's example further with a explanation so this can continue on. I would be greatly appreciated
Apologies, but I need to keep this on track and moving along.
Here's my real life example as to why the scenarios shouldn't be the same from lacrosse: In the lighter object hitting a bigger object, I weighed about 60kg and the guy I hit may have weight about 90 kg. This guy felt my hit and ultimately, he got enraged by the fact that I hit him. When I was standing still, he hit me straight on while I stopped. I felt that far more than I felt my hit on him. Therefore, I cannot believe they are the same scenario. I would say we both were moving at constant speeds since you cannot accelerate by much in contact sports without getting penalized.
  • #37
Let's remember to keep to the OP's original questions and problem parameters.
If we've exhausted the topic then we should close the thread to avoid its going totally off topic.
Take care,
Jedi
  • #38
Here's a real life bull vs bull collision
From it you can see that two equally massive bulls collide and stop. Now if one were a human running at the bull then the human would bounce back a lot more and the bull would still continue forward with reduced momentum.
Example 3 in the web page below covers your case of a more massive object striking a less massive object trying to move away.
http://www.physicsclassroom.com/cla...g-Equations-as-a-Recipe-for-Algebraic-Problem
  • #39
Yeah, it feels better to hit someone, than to be hit. But your subjective impression cannot be fully modeled with basic mechanics.
  • #40
This is better modeled in martial arts. When we prepare to spar, we tighten our muscles so getting hit in the stomach is not too bad but if we got hit in the stomach area when they were relaxed it would hurt a lot more and the wind would be knocked out of us.
It's the expected hit versus unexpected hit where we aren't prepared and more parts of your body feel the hit.
  • #41
The bull is a powered vehicle .
Because of it's high power and large mass it approximates to being a constant velocity motion source when charging .
After contact with a relatively lightweight object like a person the bull continues moving forward under power with almost the same velocity as before contact .
In reality of course the bull makes a conscious decision about what to do next after contact - this is not just a dynamics problem .
It is easier to analyse this sort of situation by considering the interaction between contacting carts with simple impact responses . Heavy cart with powerful engine v lightweight cart with feeble engine .
