Bullet colliding into block, sliding across surface with friciton
A 125-gram bullet traveling at 300 m/s embeds into a stationary 5.00 kg block, resulting in a combined initial velocity of 7.317 m/s after the collision. The block and bullet then slide on a surface with a coefficient of kinetic friction of 0.250. The force of friction acting on the block is calculated to be 12.5 N. To determine how far the block will slide before coming to rest, the work-energy theorem can be applied, relating work done by friction to the kinetic energy of the block and bullet. The discussion emphasizes finding the relationship between work, force, and distance to solve the problem effectively.
crandall
A 125. gram bullet traveling at 300. m/s strikes and sticks into a stationary 5.00 kg block of wood. The combined bullet + wood initially slides on a horizontal frictionless surface until they encounter a second horizontal surface with a coefficient of kinetic friction between the plane and the bottom of the block of 0.250. How far along the second surface will the block and bullet slide before coming to rest?
COLM, Kinematics
So far I've determined the velocity of the block+bullet with colm.
m1v1+m2v2=(m1+v2)vf
to get the final velocity as 7.317.
I've determined the force of friction to be 12.5, however I'm stuck at this part, how do I determine how far the block is going to slide?
What's the definition of "work"? (and if that doesn't lead you to the answer, you might want to look up the "work-energy-theorem." Your goal here is to find a relationship between work, force, and distance [and how that relates to kinetic energy in this case].)
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
