Why Can a Bullet Penetrate an Object Despite Constant Velocity?
A bullet does not maintain a constant velocity; it decelerates rapidly upon impact, generating significant forces. The penetration occurs not because of its initial velocity but due to the deceleration when it interacts with an object, which involves a change in momentum. Momentum and energy are key factors in this process, as they allow the bullet to exert force during the collision. The interaction with the object leads to a transfer of forces, enabling penetration. Understanding these dynamics clarifies how a bullet can penetrate despite its initial motion.
oneamp
If F=ma, why does a bullet that's going a constant velocity, have enough force to penetrate an object?
It doesn't go at a constant velocity. A bullet decelerates very rapidly.
A moving bullet doesn't have 'force', it has momentum and energy. Under the right conditions, that energy may be sufficient to allow the bullet to penetrate an object. During the collision, forces are generated that slow down and deform the bullet.
[STRIKE]And as DaleSpam stated, [/STRIKE]a bullet doesn't move with constant velocity. The air exerts a retarding force on it.
Thanks...
Doc Al said:
And as DaleSpam stated, a bullet doesn't move with constant velocity. The air exerts a retarding force on it.
I'm pretty sure that's not what he meant. I'm pretty sure that he meant that in the case being described by the OP - when the bullet hits something - it isn't going at a constant velocity, it is decelerating very rapidly, which involves a very large force.
...We've gotten almost this exact question several times in the past few days...
You could look at the bullet's behavior in a vacuum, in which case there would be no air friction. Then it would travel at a constant velocity, and when it hit something, some sort of impulse would occur, which involves forces over some period of time that change the momentum of both the bullet and whatever it's hitting, but conserve the total momentum.
This is exactly what's happening in the air, too. It's traveling through a "vacuum" of space, that also happens to be filled with air molecules. So when the bullet runs into those molecules, the interaction I described above happens. Sorry if that just sounds like rambling, but I figured another take on it might help you glean some more insight!
And if your question is specifically about how a thing moving at a constant velocity can deliver a force, then it's like the posters above were saying: when the bullet makes contact with anything else, it does accelerate (changes velocity) and that acceleration is the one in the F=ma equation, not its lack of acceleration BEFORE the impact. The bullet has no "force" if it isn't interacting with something. Hope that helps a bit!
Ah, OK. I was wondering, since I would not have said that a bullet decellerates rapidly through the air. :rolleyes:
penetration of bullet
It penetrates not due to its velocity but by the deceleration provided by the body into which it penetrates. hence by action reaction force is exerted and the bullet penetrates
hope this helps.
if there is need of further comprehension please feel free to reply.
regards
GANESH PRASAD
Mathematically,
##F=\frac{mv-mu}{t}##
For example,if a bullet(0.2kg) had an initial velocity of 500m/s and it stopped after 0.5 sec,then:
##F=\frac{0.2*0-0.2*500}{0.5}=-200N##
So the wall applied 200N on the bullet and the bullet also applied 200N.
minus sign (-) indicates the force is opposite to the direction of motion.
