Buoyancy of a pail of water problem
  • Thread starter Thread starter darkmagic
    Buoyancy Water
When a hung object is submerged in a pail of water, the overall weight of the pail and water does increase due to the buoyant force acting on the object. The tension in the string changes because the object experiences a buoyant force, which is equal to the weight of the water displaced. According to Newton's third law, the object exerts an equal and opposite force on the water, contributing to the total weight. If the pail is full, any spilled water will equal the buoyant force, maintaining the weight increase. Understanding these principles clarifies how buoyancy affects the weight of the system.
darkmagic
I have a question, if a hung object is submerged in a pail of water, does the weight of the pail with water increase. The object is still hung and no water spills.
What do you think?
Well, I think it does not add. Since the object is hung? Am I correct?
No. Ask yourself: Before the object is in the water, what's the tension in the string? Does that tension change when the object is submerged?
before, the tension is the weight of the object. when submerged, the tension change since there is a bouyant force that acts on the object. Am I correct?
Exactly.
And if the water exerts a buoyant force on the object, the object must exert an equal and opposite force on the water. (Newton's 3rd law.) So the water is being pushed down by the object.
So it adds weight. The weight added will be the weight of the object when in air, since buoyant force will be cancelled?
darkmagic said:
So it adds weight.
Yes.
No. The buoyant force isn't cancelled. But a force equal to the buoyant force will be added to the 'weight' of the pail plus water.
So buoyant force will be added? I got it. How about if water spills? The spilled water will be the buoyant force that will be out of the pail. However, the object exerts a force equal but opposite of the buoyant force, so it adds weight? correct?
If the pail starts out full to the brim, then the weight of the spilled water will exactly equal the buoyant force on the submerged object. (See Archimedes' principle.)
Ok. I got it now. Thanks a lot.
