How to Solve a Buoyancy Problem
The discussion revolves around solving a buoyancy problem involving a crown weighed in air and submerged in water. The buoyant force is calculated as 0.98 N, leading to a volume of 0.0001 m^3 (or 0.1 cm^3) for the crown. The density of the crown is determined to be 8000 kg/m^3, which is significantly lower than the density of gold, confirmed to be around 19,300 kg/m^3. Participants clarify that while the original method to find density is correct, a simpler approach exists that does not require the density of the liquid. The conversation concludes with appreciation for the collaborative effort in solving the problem.
new324
Buoyancy problem, please check my work :)
Can you check my work here?
A crown is weighed in air and submerged in water. The scale reads 7.84 N in air and 6.86 N in water.
find (a) the buoyant force (b) the volume of the crown (c) the density of the crown (d) is the crown made of gold?
(a) 7.84-6.86=.98 N
(b) Bouyant force=Volume(submerged object)*density(liquid) *gravity
so .98=v*1000*9.8 V=.0001 m^3 (=.1 cm^3)
(c) Density Object= (Weight object/Bouyant Force)*Density Liquid
p=(7.84/.98)1000 ;p=8000 kg/m^3
(d) I'm not sure the density of gold, I think its more than double this density though. So No, the crown is not made of Gold.
Thanks for any help!
Looks good to me! :smile:
Quick search shows that "A cubic centimetre of gold will weighs 19.3 grams" so that makes the gold density 19,300 kg/m3.
By the way, you don't have to use this equation to find the object density:
\rho _o = \frac{W_o}{B}\rho _l
It's correct but the dependency on the density of the liquid is not needed, since:
B\rho _o = W_o\rho _l
\rho _lv_og\rho _o = m_og\rho _l
So the liquid density cancels and you get:
v_o\rho _o = m_o
Which is (amazingly :-p) exactly the defintion of mass density. :smile: You have the object's mass, since you know its weight in air.
Looks good to me.
new324 said:
(a) 7.84-6.86=.98 N
Right.
Right. (But 1 m^3 = 1,000,000 cm^3)
Right. Though I'm used to the simpler "Density = Mass/Volume", what you've done is equivalent.
Right. The density of gold is about 19,300 Kg/m^3
Note: Chen, you beat me again! :mad:
Tsk tsk. :wink:
Chen said:
Tsk tsk. :wink:
I'm getting old and slow, I guess. :biggrin:
We both even said "Looks good to me". :-p
mmmkay, enough monkey business now, got to get back to studying Bible again. :frown:
Awesome. Thanks a lot Chen and Doc Al. It's a great thing when people compete over helping you first. Haha. :biggrin: Thanks again.
