Calculating Buoyant Force on a Helium-Filled Balloon
To calculate the tension in the line holding a helium-filled balloon, first determine the buoyant force acting on the balloon using the formula for buoyancy, which is the weight of the displaced air. The volume of the balloon can be calculated using the formula for the volume of a sphere, and then multiply this volume by the density of air (approximately 1.225 kg/m³) to find the buoyant force. Next, calculate the weight of the helium-filled balloon by adding the mass of the empty balloon to the mass of the helium it contains. Finally, apply the equation: buoyant force minus the weight of the balloon equals the tension in the string. This approach will yield the tension in the line supporting the balloon.
amjber2
buoyant forces
I was having trouble with this problem. please let me know how to approach this. thanks.
An empty rubber balloon has a mass of 0.0135 kg. The balloon is filled with helium at a density of 0.181 kg/m3. At this density the balloon is spherical with a radius of 0.400 m. If the filled balloon is fastened to a vertical line, what is the tension in the line?
You should show some of ur workings b4 we can help. Alright, just a little clue to get u started. Upthrust- weight= tension of string.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
