By how much does the thermal energy of the gas change?
The discussion focuses on calculating the change in thermal energy and heat transfer for a thermodynamic process involving hydrogen gas. The user successfully determined the work done on the gas as -50.7 J and calculated the change in thermal energy as -15 J. They struggled with the heat energy transferred to the gas, initially guessing 24.9 J, which was incorrect. After clarification, they found the correct value to be +25.8 J, confirming that heat added to the system is always positive. The conversation concludes with the user expressing gratitude for the assistance received.
mssca
This is my very first post... :) I found some help here: https://www.physicsforums.com/showthread.php?t=277092 But I have a difficulty in sloving second and third part
The figure shows(check the link) a thermodynamic process followed by 1.90×10^−2 of hydrogen (link to the graph: http://tiny.cc/c9m0h
http://session.masteringphysics.com/problemAsset/1074025/3/knight_Figure_17_65.jpg
I get -50.7J for the work done on the gas which is right... now they want to calculate:
AND
How much heat energy is transferred to the gas?
Please help me... I spent hours reading the textbook, but I still don't get it.
Eth=W+Q
pV=nRT
Q=nCdeltaT
By how much does the thermal energy of the gas change? After using above equations and
I get dalta T = 64.15859142 AND I get Eth=-15
For this question "How much heat energy is transferred to the gas?" the heat energy is what?
Please help me... Thank you
You also know that a monotonic gas, such as hydrogen, has a change in internal energy as such:
∆E=3/2 n R ∆T
You can use some ideal gas law and some other reasoning to change this to an expression with PV. Once you know the energy change, the heat should be easy. Give it a try. :)
∆E=3/2 n R ∆T
I got it! Except for the last section "How much heat energy is transferred to the gas?" Is is -25.8 oR +25.8...? My dad thinks it should be +25.8. I have the answer for the last section but I don't know if it is +/-. How do you determine +/-? For part B I entered 24.9J but it came out wrong and when I entered -24.9J it came out right.
Thanks.
Fortunately, heat has only one convention, which is heat added to the system.
∆U=Q+W (work done on the system)
-24.9=Q-50.7
Q=25.8
So, the gas did a certain amount of work in expanding (work was done by the gas), the internal energy decreased, and heat was added to the system.
-24.9=Q-50.7
Q=25.8
Got it! THANK YOU SOOOO MUCH!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
