Bypass time of satelite arround Mars
10 replies · 2K views
antoman
On high 150km above the surface of Mars, there is satelite That is ciculating arround Mars. What's his bypass time? Radius of Mars is 3400km.
I found equation like this :
t= (2*r(R+h)^(3/2))/(sqrt(g0*R^2))
R=r+h
r=3400km
h=150km
But when i try to calculate like this, i totally miss the actual time. I know bypass time(solution) is 110 minutes.
What value of g0 are you using? What units for r and R are required?
welcome to pf!
hi antoman! welcome to pf! :smile:
let's put that into english :wink: …
At a height of 150km above the surface of Mars, there is a satellite that is orbiting Mars. What's its period? The radius of Mars is 3400km.​
hmm … don't you need to know either the mass of Mars, or the gravitational acceleration (g) at the surface? :redface:
g0=9,81m/s^2
i could calculate g at surface using g=g0*R^(2)/(R+h)^2, but then again i have no idea what to use it for
.. nevermind g0 is different on Mars then on Earth so..
Ok i made some changes, so now
r=R+h
R=3400km
h=150km
g0=3,7 m/s^2... assuming i should of know g0 from mars.
I calculated and it came out t=7261412,315 km/s...:confused:
You've got R and h in km and g0 in m/s^2. Don't you think you have a problem with your units?
I used 3.6*10^-3 km/s^2 for g0 when i calculated, so its (km*km^(3/2))/sqrt(km*s^(-2)*km^2). Then km^(3/2)/km^(3/2)=1, so all it stays is km*s.
Repair me if I am wrong :)
I'm repairing you.
Do you have the right formula?
What if R and r have to be in meters instead of km?
SteamKing said:
I'm repairing you.
No, i don't think the formula is right, that's why i asked for help.
Now i know what was the problem :D
Correct formula is:
t=(2∏*(...))/sqrt(...)
+ g0 to km/s^2, and it all works out perfect, iven makes more sense :)
