Calculating Arc Length of a Curve: Caculus III Formula and Reparameterization
  • Thread starter Thread starter dswatson
    Arc
The discussion revolves around calculating the arc length of a parametric curve defined by r(t) = <5sin(t), 4cos(t), 3cos(t)> for the interval 0 < t < 2π. Participants are tasked with finding a formula for the arc length function s(t) and reparameterizing the curve with respect to arc length.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the correct formula for arc length, with some initially referencing polar coordinates before realizing the curve is parametric. There are attempts to derive the arc length integral and questions about the derivatives of the components of the curve.
The discussion has progressed through various attempts to compute the arc length, with some participants clarifying their understanding of derivatives and integrals. Guidance has been provided on how to approach reparameterization once the arc length function is established.
Participants express confusion regarding the reparameterization process and the relationship between the arc length function and the parameter t. There are discussions about the bounds for the arc length parameter and how to express the curve in terms of s.
dswatson
consider the curve r(t)=<5sin(t),4cos(t),3cos(t)> where 0<t<2*pi.
Find a formula for this curve's arc length function: s(t). Also, compute the total arc length.
Reparameterize this curve with respect to arc length (find r(s)) Don't forget to specify the range for the arc length parameter: ?a?<s<?b?.
I am completely lost. If someone could step me through at least the first part I would greatly appreciate it. Thanks in advance.
The general form for the length of an arc in polar coordinates is given by
Integral of
[ sqrt( r^2 - (dr/da)^2 ) ] da
Where "da" means d-theta
I have this in my notes but am still lost.
You aren't in polar coordinates. It's a parametric curve. Arc length is the integral of sqrt(x'(t)^2+y'(t)^2+z'(t)^2) dt. Try that.
ok so i have gotten this far.
int[sqrt{(25+sin^2(t))}]
where do I go from here? It doesn't factor or that would make it easy.
Notice that Dick said the arc length is the integral of sqrt(x'(t)^2+y'(t)^2+z'(t)^2) dt!
You only have sqrt(x(t)^2)!
Notice that x'(t) denotes the derivative of x(t) wrt. t. You also need to include y'(t)^2 and z'(t)^2. You should be able to simplify nicely if you do this correctly. Post what you get !
I feel like I did do all of the derivatives...
I did x'=5cost, y'=-4sint, and z'=-3sint
then square them...
x'^2=25cos^2(t), y'^2=16sin^2(t), and z'^2=9sin^2(t)
the add them but convert x'^2 to a factor of sin^2(t) first.
25cos^2(t)=25(1+sin^2(t)) then distribute and I ended up with...
int[sqrt{25+25sin^2(t)+16sin^2(t)+9sin^2(t)}dt]
then add up the sine terms...
int[sqrt{25+50sin^2(t)}dt]
this is where I'm stuck...did I do something wrong?
ok nevermind i see where i messed up...i shouldn't have made the cos a sin.
If i leave it as it was before...
int[sqrt{25cos^2(t)+16sin^2(t)+9sin^2(t)}dt]
then just combine the sin terms i get
int[sqrt{25cos^2(t)+25sin^2(t)}dt]
this gives me...
int[sqrt{25}
equals...
int[5]
equals
5t over interval 0 to 2*pi
so my answer is 10*pi right?
Btw, I did misread your post #3 but I'm glad you figured out your problem !
That does look correct
ok...so assuming that is is correct...where do I begin on the next step?
I am a little behind in calc and am trying to catch up...
I now have to "reparameterize this curve with respect to arc length (find "r(s)"). Don't forget to specify the range for the arc length parameter: [?a?]\leq[/?b?] "
this is a quoted question and have no clue how to do it...any suggestions?
Well, you found the arc length function s(t). Why not try solving for t?
After doing this how would you reparameterize the curve? With a little thinking you'll get the new bounds !
my problem is that i don't what you mean to solve for t...my equation for arc length was 5t evaluated over 0<t<2*pi. To solve for t, what is 5t equal to? this is where I'm completely confused...
is this simply s(t)=5t plugged back into the original r(t)?
yeah, so t = s/5
What range of values is allowed for s now?
0<s<10*pi ?
well nevermind that doesn't work because there are no "s"'s in the eqn
so my final answer so far is...
r(s)=<5sin(s/5),4cos(s/5),3cos(s/5)>
so are my new parameters...0<s/5>2*pi so...0<s<10*pi
looks good to me
awesome! thank you so much for all of the help
I really appreciate it...
