Calc I - Finding average velocity using integration
Integration can be used to demonstrate why car 2 traveled farther than car 1 by calculating the area under each car's velocity function over the same time interval. The larger area under car 2's velocity curve indicates a higher average velocity compared to car 1. To find the average velocity, one can integrate the velocity functions from 0 to 30 seconds and apply the average value formula. Additionally, considering acceleration may provide further insight into the differences in distance traveled. Using integration is a valid approach to analyze the average velocities of both cars.
opticaltempest
Can I use integration to show why car 2 traveled farther than car 1 over a given time interval?
Here is some of the problem,
I have the following graph of two different velocity functions
for two cars.
http://img97.imageshack.us/img97/5696/graph1kv.jpg"
The viewing window of this graph is x from 0 to 30
and y from 0 to 100.
After integrating the velocity function I found the position function.
Estimating the distances traveled by both cars from time t = 0
to time = 30 I find,
Car 1 whose velocity function is the thin line on the graph
traveled approximately 964.11 feet.
Car 2 whose velocity function is the thick line on the graph
traveled approximately 1977.9 feet.
By looking at the graph it is obvious that the thick line has
a larger region under the curve (from the curve to the x-axis) than
the thin line.
Is it possible to integrate from 0 to 30 on each velocity function and show that the larger regions under the curve correspond to a higher average velocity over time interval 0 to 30 which is why car 2 traveled farther? Am I on the right track about dealing with the velocities of the cars? Should I also consider their acceleration as being a reason for why car 2 traveled farther?
I need explain why car 2 traveled farther. Is it possible to use integration to find average velocity?
In the original problem velocity is given every 5 seconds from 0 to 30 for each car. I could find the secant line over each 5 second interval and average those secant lines to find the approximate average velocity from time 0 to 30, correct? If possible I want to try to use integration to solve this.
Thanks
You have two velocity graphs and you want to find the average velocity. Your instincts are correct to integrate, but it's not just integrating from 1 to 30. Calculating the average value of a function, f(x), from a to b can be done as follows:
A(x)=\frac{1}{b-a}\int_{a}}^{b}f(x)dx
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 33 ·
31K
