Calculate a^n, if n=1000000 then it should be calculated in 40 multiplications
  • Thread starter Thread starter .d9n.
.d9n.
Given integers a and n, where n > 0, how many multiplications
are needed to calculate a^n? You are not expected to produce a
precise answer, but if n is a million it should become clear from
your answer that 40 multiplications will suffice.
y=a^n so n=log_a(y)
so if n=1000000
n=1000000=log_a(y)=
or
y=e^(nlog(a))=e^(1000000log(a))
not sure how I'm meant to do this, as far as i am (aware/ can find) there isn't a relationship between a and n that could do it to 40 multiplications as this would mean you have to knwo a^25 000 and then maybe multiply this by 40, but I am pretty sure that's wrong.
any ideas on where to look?
Calculate a4 in 2 multiplications and it should be clear how to proceed
so by two multiplications do you mean
a^2 x a^2
so for the qu you mean
a^25000 x a^25000 x ... x a^25000 - 40 times
say n=1000000
is this what you mean
a^1000000=a^500000 x a^500000 =a^ (a^25000)^20 x (a^25000)^20 = (a^25000)^40
or
a^2^500000= a^2^2^250000 = a^2^2^2^125000 = a^2^2^2^2^62500 = a^2^2^2^2^2^31250 ...
or neither
a6 in three multiplications:
First multiplication:
$$a\times a=a^2$$
Second multiplication:
$$a\times a^2 = a^3$$
Third multiplication:
$$a^3\times a^2=a^6$$
Idea is to reuse what you already calculated earlier.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
