narendra
- 3
Light takes "t1" seconds to travel a distance "x" cm in vacuum and same light takes "t2" seconds to travel "10x" cm in a medium.The critical angle for the corresponding medium is .. ??
narendra said:Light takes "t1" seconds to travel a distance "x" cm in vacuum and same light takes "t2" seconds to travel "10x" cm in a medium.The critical angle for the corresponding medium is .. ??
narendra said:the angle of incidence at which angle of refraction becomes 90 degress is critical angle.(C)
relation is
angle of refraction = 1/sinC
Another thing that i know is refractive index for vacuum is "1"
This is not homework..i am preparing for a competetive exam.
I could not figure out how to solve this problem.
The formula for calculating critical angle is sin-1(n2/n1), where n1 is the refractive index of the medium through which the light is traveling and n2 is the refractive index of the medium in which the light is being refracted.
Critical angle is the angle at which light traveling from a more dense medium to a less dense medium will be refracted at a 90 degree angle. This is the angle at which total internal reflection occurs, meaning that all of the light is reflected back into the more dense medium instead of passing through the boundary.
No, critical angle cannot be greater than 90 degrees. This is because at 90 degrees, the light is refracted at a 90 degree angle and all of it is reflected back into the more dense medium. Any angle greater than 90 degrees would result in the light passing through the boundary instead of being reflected.
The refractive index of a medium is directly proportional to the critical angle. This means that as the refractive index of the medium through which the light is traveling increases, the critical angle also increases. This is because a higher refractive index means that the light will be refracted more, making it more likely to be reflected back into the more dense medium.
The critical angle plays a crucial role in optical devices such as fiber optic cables and prisms. It also explains phenomena like mirages and the sparkling of diamonds. Additionally, understanding the critical angle can help us determine the most efficient angles for light to travel in order to minimize loss of light energy.
