Calculate Energy and Velocity of Thrown Objects: Beach Ball and Fastball
  • Thread starter Thread starter eck0616
    Energy Physcis
The discussion focuses on calculating the energy and velocity of two thrown objects: a beach ball and a fastball. For the beach ball, calculations include its maximum height and impact speed, considering both no air resistance and a constant air resistance force of 10N. The fastball's analysis involves determining its gravitational and kinetic energy at release and its speed upon reaching home plate. Participants express confusion over the calculations, particularly regarding the beach ball's maximum height. The thread emphasizes the need to show work for homework assignments to receive assistance effectively.
eck0616
1 A beach ball is thrown straight up with a speed of 10m/s from a point 2 m above the ground
a) Assuming no air reistance, calculate how far up the ball will go
b)At what speed will the ball eventually hit the ground?
c) If the air resistance exerts a constant force fo 10N during the journey, calculate the new maximum height and maximum speed of the ball.
2. A pitcher throws a fastball, off target, at a speed of 90 km/h and hits home plate. The ball of mass 0.14 kg is 2.2 m above the ground when it leaves the pither's hand
a)What is the total gravitational and kinetic energy of the ball at the time of release?
b) What is teh ball's kinetic energy when it reaches home plate?
c) How fast is the ball moving when it collides with the home plate?
As this is homework, you'll need to show an attempt first.
What are your thoughts on this?
honestly I'm lost
for 1 a) i got 50m
by first finding the time
then the distance
t=2/10
=0.2
d=v/t
=10/0.2
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
