Calculate Mass of Planet with Density 4950 kg/m3 and Velocity 3.55 km/s
  • Thread starter Thread starter clockworks204
    Mass Planet
The discussion centers on calculating the mass of a newly discovered planet with a density of 4950 kg/m³ and a satellite orbiting at a velocity of 3.55 km/s. The initial formula used was incorrect, leading to a mass calculation of 3.3 x 1047 kg. The correct approach involves using the formula m = √(V6) / (4/3 * G3 * π * density), where G is the gravitational constant (6.67E-11). The user acknowledged an error in their calculations and expressed intent to utilize LaTeX for clarity in future discussions.
  • Understanding of gravitational physics and orbital mechanics
  • Familiarity with the formula for mass calculation involving density and velocity
  • Knowledge of LaTeX for formatting mathematical equations
  • Basic proficiency in unit conversion (e.g., km/s to m/s)
  • Review gravitational physics principles, focusing on mass and density relationships
  • Learn how to properly format equations using LaTeX
  • Practice unit conversions, particularly for velocity and density
  • Explore advanced orbital mechanics and their applications in astrophysics
Astrophysicists, physics students, and anyone interested in planetary science and gravitational calculations will benefit from this discussion.
clockworks204
1. A newly found planet with a density of 4950 kg/m3 has no atmosphere and is orbited by a low altitude satellite with an orbital speed of 3.55 km/s. What is the mass of the planet?
2. density*velocity=mass
G= 6.67E-11
3. After a process of equations, I ended up with mass= sqrt(V^6)/(G^3*density*4/3*pi). Subbing in the values and converting 3.55 km/s to 3550 m/s, I get sqrt(3550^6)/(6.67E-11)^3(4950)(4/3*3.14) to get an answer of 3.3*10^47 kg
This isn't the right answer, and I'm not sure where I screwed up. Much appreciated..
You might try to process the equation again. If you show your work we can help more.
As you have written your formula, the only thing under the √ sign is the v6 term. According to my calculations, there should be more than that. Although it might just be your typing notation. Perhaps [itex]\LaTeX[/itex] would be of good use here.
For your convenience I have written your calculated formula in LaTeX (from what I think you meant, anyway -- it's difficult to tell with just text):
[tex]m = \frac{\sqrt{v^6}}{\frac{4}{3}G^3 \pi \rho}[/tex]
You might wish to modify that formula.
[Edit: If you don't know [itex]\LaTeX[/itex], but whould like to use my equation as an example, click on it and it should open up the LaTeX code which you can copy, and modify in your own post. Or, we can just stick with normal text if [itex]\LaTeX[/itex] doesn't suit you. Alternately, you can click on the "[itex]\Sigma[/itex]" symbol in the upper right hand corner of the editing toolbox (make sure you "Go Advanded" if you don't see it), and there is a menu there that you can use to generate LaTeX code from items on the menu.]
Yep you caught my error. I simply missed taking the square root of the solution because there was quite a bit going on. I'll try using Latex next time...I was unaware of it. Thank for you help collinsmark.
  • · Replies 62 ·
