Calculate Net Calorific Value at 25°C
  • Thread starter Thread starter GeorgeP1
    Net Value
23 replies · 8K views
GeorgeP1
A fuel gas consists of 75% butane (C4H10), 10% propane (C3H8) and 15% butene (C4H8) by volume.
It is to be fed to the combustion chamber in 10% excess air at 25°C, where it is completely burnt to carbon dioxide and water. The flue gases produced are to be used to generate 5 bar steam from water at 90°C
Net calorific value (MJ m–3) at 25°C of:
Butane (C4H10) = 111.7 MJ m^3
Butene (C4H8) = 105.2 MJ m^3
Propane (C3H8) = 85.8 MJ m^3
I need help on how to calculate: -
the net calorific value (CV) per m^3 of the fuel/air mix at 25°C ?
the net calorific value (CV) per kmol of the fuel/air mix at 25°C ?
[/B]
[/B]
Net cv per m3 = 58.65 mJ / m^3
Net cv per kmol = 1466.25 mJ / kmol
These attempts are incorrect but I don't know where I have gone wrong. any help is much appreciated.
thanks in advance
on Phys.org
Hi chestermiller
yes flue gas is 1 bar.
I make it a total of 35.35 moles with 10% excess air.
I make it :
butane - 0.75mol
propane - 0.1mol
butene - 0.15mol
oxygen - 6.3mol
10% excess air = 0.63 + 6.3 = 6.93mol
nitrogen = 6.93 x 3.76 = 26.07mol
is this correct?
GeorgeP1 said:
I make it :
butane - 0.75mol
propane - 0.1mol
butene - 0.15mol
oxygen - 6.3mol
is this correct?
That's the correct number of moles in the mixture, if you start with 1 mole of pure fuel. What is the total number of moles here, and, using the ideal gas law, what volume does this total number of moles of gas occupy?
total number of moles is 34 moles.
n = pV / RT
n = no. of moles
p = pressure
v = volume
R = constant (8.314)
T = temperature
n = (101300 x 1) / (8.314 x 298)
n = 40.89 moles
n = pV / RT
n = no. of moles
p = pressure
v = volume
T = temperature
n = 40.89 moles
So, if 1 m^3 of the gas contains 40.9 moles, and the total volume you calculated for the case of 1 mole of pure fuel is 34 m^3, how many moles of each species in the fuel mixture is present in 1 m^3 of mixture?
V = (n/p)RT
The volume in the ideal gas equation for 34 moles of gas is 0.83 M^3
butane - 0.902 mol
propane - 0.12 mol
butene - 0.181 mol
O2 - 8.33 mol
N2 - 31.36 mol
GeorgeP1 said:
butane - 0.902 mol
propane - 0.12 mol
butene - 0.181 mol
O2 - 8.33 mol
N2 - 31.36 mol
This agrees with what I got.
Now, I assume that those net caloric values that they give you is for burning 1 m^3 of each of the pure three species (i.e., for burning the number of moles of each species that occupy 1 m^3 at 25 C and 1 bar). Is that correct?
great...
yes the net cv is for 1 m^3 of each gas.
I make it 0.02206 M^3 for butane
does that make the net CV for butane 2.46 Mj / M^3
propane = 0.003 m^3
= 0.2574 MJ /M^3
Butene = 0.0044 M^3
= 0.463 Mj / M^3
Total = 3.1804 Mj /M^3
Excellent. Thanks chestermiller
My previous attempt was a country mile out then.
what about the net calorific value (CV) per kmol of the fuel/air mix at 25°C ?
Any ideas?
so per kmol is 40.89 mols / 3.1804 = 0.013 Mj / Kmol
does this make sense??
