Calculate Pressure vessel Collapse Pressure
8 replies · 5K views · last reply
Christy001
I have a simple cylindrical pressure vessel with thickness 100m and inner radius 254mm,.the cylnder has flat head closed ends but these are thickness 30mm. I need to calculate the pressure that would cause the vessel to collapse given material properties E=207Gpa, poissons 0.3, yield stress = 207Mpa
I know that there are equations out there for hoop and radial stress which are quite simple but can I just assume I should use only for thickness 30mm
I have used the simple equations for hoop and radial stress however I'm not sure if this is correct or not [/B]
In theory I was thinking of using the formula for hoop stress (as hoop stress is the max stress rather than axial or radial) as this problem is a thick walled rather than thin walled pressure vessel. I do have the equations which are below. So I'm thinking that if I use 207Mpa as the value for hoop stress( which is the yield stress) , a and b though are outer and inner radius therefore I'm confused as this doesn't consider the thickness of the end caps, rather the thickness of the cylinder.
Are these really the dimensions you want to talk about? 100 thick is a petty thick wall!
Christy001 said:
Sorry typo - 100mm not m !
That makes quite a bit of difference.
With this mod, the thick walled pressure vessel equations should apply.
Google "radial compressive buckling of thin walled cylinders." This is a stability problem analogous to axial compressive buckling of rods. To see the modes of buckling of cylinders, just suck some of the air out of an empty 2 liter bottle. You will see the quadra-lobal buckling pattern.
Thanks - but I don't think thin-walled would apply in this case ? Because of the dimensions wouldn't this be classified as a thick walled pressure vessel ?
It would be classified as a thick walled vessel. But it is not clear whether this same mode of instability could occur in vessels with thickness-to-diameter ratios and pressure differences characteristic of your system. I wanted to make you aware that such an instability could be possible, and provide some equations for crudely estimating whether it might need to be addressed.
