Calculate Rotator Drum Torque for In-Vessel Composting System
  • Thread starter Thread starter compostguy
    Drum Torque
The discussion focuses on calculating the necessary torque for a 21 ft. long, 4 ft. diameter in-vessel composting system, which weighs between 2000-3000 lbs. and can hold up to 2000 lbs. of compost. The design includes a hydraulic pump powered by a 4-5 HP gas motor and a 60:1 gear reduction box. Participants share formulas for calculating horsepower and torque, emphasizing the relationship between torque, horsepower, and motor speed. There is also a light-hearted exchange about coincidences between the participants, including shared names and backgrounds. The conversation highlights the technical challenges of predicting torque and RPM for the hydraulic assembly.
compostguy
I am designing an in-vessel composting system - a 21 ft. long 4 ft. diameter steel tube that is mounted and spun on wheels by a hydraulic pump/turbine assembly, coupled to a 60:1 gear reduction box - the hydraulic pump will likely be powered by a small 4-5 HP gas powered motor.
My question relates to calculating the necessary torque to spin this vessel, and how to determine how much speed is altered. The vessel weighs probably 2000-3000 lbs. and will hold probably up to 2000 lbs. of compost.
How can I calculate the necessary torque to spin this? I suspect it has something to do with the circumfrence, the radius from the axis of rotation, etc., but don't really know how it all fits together.
Thanks!
-Colin
Horsepower for rotating objects:
HP = (TxN)/(5250)
where
HP = Horsepower
T = Torque (lb-ft)
N = Motor Base Speed (RPM)
Torque for rotating objects:
T = (HPx5250)/N
where
T = Torque (lb-ft)
HP = Horsepower
---------------------------------- Someone please let me know if I am wrong
That is what i remember from class, its a little ironic how my teacher JUST went over that with me after class, and now u ask... P.S. another ironic thing.. my name is colin too... and ur the first colin I've found to spell it the same too... just some irony for you :biggrin:
did that help?
thanks!
Thanks for the tip Colin - I don't know what the rpm and torque output will be for the hydraulic assembly but am still looking around for answers, would be nice to be able to predict that...
Weird coincidence - I went to high school in VA and did the IB program at George Mason HS in Falls Church - pretty funny! And now I'm still struggling with these little physics details!
Are you serious?? that is so weird! that's not far from where i live actually. only about a 3 hour drive at most!
we lived in the same state(within 3 hours of one another).. went to the same school program.. have the same name... Are both interested in MAth and Science(and are rather good at it)... and both joined these formums the same day.. What a coincidence ! Is it just me or is that REALLY ironic?!
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
