Calculate Tension in String for Frequency of 120Hz
  • Thread starter Thread starter thereddevils
    Frequency Waves
To calculate the tension in a string vibrating at a fundamental frequency of 120 Hz, the wave speed must first be determined using the formula f = v/(2L), resulting in a wave speed of 120 m/s. The relationship between tension, mass per unit length, and wave velocity is given by the equation T = μv², where T is tension, μ is mass per unit length, and v is wave speed. The mass per unit length can be calculated from the string's mass and length, yielding μ = 0.0029 kg/m. By substituting the values into the tension equation, the tension in the string can be calculated, leading to the conclusion that understanding these relationships is crucial for solving the problem accurately.
thereddevils
One end of a string of mass 1.45 g and length 50.0 cm is attached to a frequency generator and the other end to a weight holder which hangs over a fixed pulley . The part of the string between the generator and the pulley is horizontal . THe string is set to vibrate . Several weights are added until a fundamental frequency of 120 Hz is achieved . Calculate the tension in the string when the fundamental frequency is achieved .
f=v/2L
120=v/(2 x0.05)
v=120 m/s
not really sure whether this is even an attempt . I do not know how to link the v i got here to tension in the string .
Try to find the relation between tension, mass per unit length and the velocity of the wave in the stretched string.
i am not sure how to relate them since the unit of tension is kgm/s^2 , mass per unit length is kg/m and velocity , m/s
how can i combine m/s and kg/m to get kgm/s^2 ?
What is the value of
\sqrt{\frac{kgm/s^2}{kg/m} = ?}
