Calculate the average force on the ball during contact
dylan61990
A .145 kg pitched baseball moving at 35 m/s strikes a bat and is popped straight up (forming a 90 degree angle)to a height of 55.6 m before turning around. If the contact time is .50 seconds. calculate the average force on the ball during contact.
p=mv
impulse=ft
m1v1+m2v2 = m1v1 prime +m2v2 prime
delta ft= delta mv
I honestly have no idea but this is what i did
f=mv/t=.145(35 m/s)/.50 s= 10.15 N
Hi Dylan and welcome to the Forums,
Could you post your attempt at answering the question please?
the answer in the book says that it is 1.4 times 10 to the 4 Newtons, 43.3 degrees.
I just don't know how they got that, or what the degrees mean.
Okay, let's take this one step at a time. If you thew a ball straight up from ground level, what would be the minimum velocity required such that it reached a maximum height of 55.6m?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
