Calculate the density of the material of which the sphere is made
The problem involves calculating the density of a hollow sphere with given inner and outer radii, which is floating half submerged in a liquid with a specific gravity of 0.80. The discussion revolves around the application of buoyancy principles and volume calculations related to the sphere and the displaced liquid.
  • Participants discuss the volume calculations for both the sphere and the shell material, questioning the accuracy of the original calculations. There are considerations about the buoyant force and its relation to the weight of the sphere, as well as the volume of liquid displaced.
Multiple interpretations of the problem are being explored, particularly regarding the calculations of volume and weight. Some participants have identified errors in the original calculations and are working towards clarifying the correct approach without reaching a definitive conclusion.
There is an ongoing discussion about the assumptions regarding the material inside the sphere and the implications of the sphere being half submerged. Participants are also addressing the need for accurate volume calculations to determine the density of the sphere's material.
anyone1979
A hollow sphere of inner radius 8.0 cm and outer radius 9.0 cm floats half submerged in a liquid of specific gravity 0.80. Calculate the density of the material of which the sphere is made.
Density of water = 1 * 10^3 kg/m^3
inner radius = 8.0 cm = 8 * 10 ^-2 m
outer radius = 9.0 cm = 9 * 10 ^-2 m
specific gravity = Density of liquid / density of water
Density of liquid = specific gravity * density of water = .80*1000 = 800 kg/m^3
V = (4 pi / 3) * (outer radius^3 * inner radius^3) = 9.09 *10 ^-4 m^3
weight of liquid = density of liquid * V * gravity = 7.127 N (buoyant force)
weight of sphere = weight of liquid + buoyant force = 7.127 + 7.127 = 14.254 N
mass of sphere = weight of sphere / gravity = 14.254/9.8 = 1.454 kg
density of sphere = mass of sphere / V = (1.454/(9.09 * 10^-4)) = 1.6 * 10^3 kg/m^3
-----All the work seems right, but I think the answer is not right. especially the calculation of the weight of the sphere. Can anybody help?
I suppose the sphere is filled with air? In that case the volume of the displaced liquid is just (4 pi/3)*outer radius^3 but only half of the sphere is submerged so the displaced volume is (4 pi/3)*outer radius^3/2.
The weight of the displaced volume is equal to to total weight of the sphere.
the mass of the sphere is then easy.
to find the density you will then have to use the volume of only the shell (as you did)
OK.
This is the volume of the shell material (not the sphere). I assume you meant to write [itex]R_o^3 - R_i^3[/itex]. You'll need the volume of the sphere as well.
Not sure what you're doing here: The buoyant force equals the weight of the displaced fluid. What's the volume of fluid displaced?
And the buoyant force also equals the weight of the sphere, since its floating.
Once you properly calculate the weight of the sphere, this method will give you the density of the material.
Thanks, I just realized it...
I calculated all wrong
Doc Al said:
OK.
Thanks...I realized my error now.
I made a mistake on the calculation
Sorry guys, I had a brain fart.
I just realized my mistake...You guys are both right.
Thanks for all your help
anyone1979 said:
This is the volume of the sphere material:
You mean:
[tex]V = \frac{4 \pi}{3} (R_{outer}^3 - R_{inner}^3)[/tex]
This is the volume of the sphere:
Vs = (4 pi / 3) * (outer radius^3) = 3.1 * 10 ^-3 m^3 = volume of displaced liquid
That's the volume of the sphere. Is the entire sphere submerged?
weight of liquid = density of liquid * V * gravity = (buoyant force)
Wl = 800 * (3.1 * 10 ^-3) *9.8 = 24.3 N
Correct this.
So what about the volume of the sphere material since I am trying to find the density of the material of the sphere...I was thinking I needed to use that volume.
You'll need the volume of shell material when calculating the density. First find the mass.
Thanks for all your help...
  • · Replies 55 ·
  • · Replies 23 ·
