Calculate the force of ball on an incline leaning on a wall
The discussion revolves around calculating the force of a ball resting on an inclined plane while touching a vertical wall, specifically focusing on the force acting on the wall (Fw). The problem states that the ball has a radius of 3cm and weighs 1kg, with friction neglected. The initial confusion arises from the relationship between gravitational force and the components of the forces acting on the ball. Ultimately, it is clarified that the force acting on the wall can be expressed as Fw = tan(alpha) kg.wt, derived from the vertical and horizontal components of the reaction forces from the incline. The participants conclude that the incline provides the necessary vertical force to counteract gravity, leading to the correct formulation of Fw.
Amit86
Hi all,
I'm working on a problem from the Feynman exercise book, and have been racking my brains for an answer, so would really appreciate some help here. The problem seems simple enough:
A ball with a 3cm radius, weighing 1kg rests on an inclined plane (angle alpha) and also touches a vertical wall. Neglect friction.
(see attached diagram)
What is the force of the ball acting on the wall (Fw)?
The answers in the back gives
Fw= tan(alpha) kg.wt
I got the force due to gravity acting down the plane, Fr = 9.81.sin(alpha). The horizontal component of this force, which to my mind is the force acting on the wall, is
Frhor=9.81* sin(alpha)cos(alpha)
What am I missing here?!
Thanks!
Amit
Amit86 said:
Hi all,
Thanks!
Amit
Hello Amit86. Welcome to PF !
The only forces acting on the ball are gravity, and the two forces supplied by the two surfaces. Right ?
Can the vertical wall counteract the force gravity exerts on the ball?
Hi, Sammy. That's correct.
There are two questions I asked.
I imagine the vertical wall can counteract the force
(By the way, there is a "Reply" feature in the lower right-hand corner of the message screen that's helpful with dialogue.)
Can the vertical surface produce a force on the ball that has a vertical component?
(There's no friction.)
As far as I can tell, I don't think it can. "both surfaces have negligible friction"
Right.
Therefore, only the incline can provide a force which has the vertical component necessary to counter act the gravitational force. Right?
SammyS said:
Right.
I suppose that's true.
You say things like "I imagine", "as far as I can tell", and "I suppose". Do you know in what direction gravity acts? Do you know in which direction the force from the wall acts?
Of course I do; check the diagram. I am looking for some insight into where the tan(alpha) comes from. I've provided all the information given in the question, I need to get some sense of how to proceed with a solution, and would appreciate constructive advice.
SammyS said:
Right.
This should help you to find the vertical force the incline needs to exert on the ball.
okay thanks!
Amit86 said:
okay thanks!
Ok so I think I've got then...
The vertical component of the reaction force of the plane = the total gravitational force (i.e 9.81 x 1kg), so the horizontal component of reaction force of the plane would be 9.81*tan alpha Newtons or
Fw= tan(alpha) kg wt
Thanks for your help!
Correct !
Notice that this vertical force is greater than the vertical force that the incline exerts for the case when the ball is allowed to roll.
