Calculate the inductance of a solenóide wound on an iron core
To calculate the inductance of a solenoid with an iron core, it is essential to consider the effective permeability, which is typically lower than the relative permeability due to the presence of air in the magnetic path. The formula for inductance requires incorporating both the permeability of free space (uo) and the effective permeability of the iron core (ur). There is a discussion about the need to adjust the formula for magnetic field strength (B) to include a division by length (L). An example calculation is requested to clarify the application of these principles in creating an electromagnet. Understanding these factors is crucial for accurate inductance calculations in solenoids.
Teslas
Hello friends of the forum! I'm here with a doubt! I have a solenoid of cross-sectional area 5cm and length 9cm with iron core of relative permeability (ur) 9,000, I wonder how to calculate this silenoid!
I think the difficulty is that the effective permeability of the core will be much less than 9,000 because the magnetic path is partly air. This problem comes up in connection with ferrite rod antennas, and there is an article here: http://g3rbj.co.uk/wp-content/uploads/2014/06/Web-The-Inductance-of-Ferrite-Rod-Antennas-issue-3.pdf
My question is
Code:
  [ATTACH=full]238238[/ATTACH]
Teslas said:
My question is
Teslas said:
My question is
In the case of the air core, we see the formula with uo in it. But for the second case, iron core, we must also multiply by the effective mu of the magnetic path.
Likes Teslas
[QUOTE = "tech99, post: 6127760, member: 477979"] No caso do núcleo de ar, vemos a fórmula com uo nela. Mas para o segundo caso, núcleo de ferro, devemos também multiplicar pelo mu efetivo do caminho magnético. [/ QUOTE]
Amigo, obrigada por me responder! Estou tentando fazer um eletroímã! E eu não conheço a bitola do fio, não sei a equação, alguém poderia colocar um exemplo com essa fórmula que eu coloquei? Yess permeability magnetc of iron core yesss!
This question is magnéticFild ( B)
Teslas said:
This question
You are correct, we must multiply by the magnetic permeability of the vac (uo) together with the permeability of the magnetic nucleus (ur) in this image that I put, I am in doubt in this formula, B = k.uo.nl, this formula is missing divide by length (L) am I right?
