Calculate the mass of steam condensed
A jet of steam at 100 degrees Celsius condenses into a block of ice, resulting in a total mass of 206 g of water at 0 degrees Celsius. The specific heat capacities and latent heats provided are crucial for calculating the mass of steam condensed. There is confusion regarding the calculations, with one participant consistently arriving at 68.5 g instead of the expected 22.6 g. Key considerations include the initial temperature of the ice and the cooling of the condensed steam from 100 to 0 degrees Celsius. Accurate application of the heat transfer equations is essential for resolving the discrepancy in the mass of steam condensed.
Cervelo
A jet of steam @ 100 degrees Celsius is directed into a hole in a large block of ice. After the steam has switched off, the condensed steam and melted ice are both a 0 degrees Celsius. The mass of water collected is 206 g. Calculate the mass of steam condensed.
Specific heat capacity of water is 4200
Specific heat capacity of ice is 2100
Latent heat of fusion is 330
Latent heat of vaporization is 2260
I keep on getting 68.5g as an answer but apparently it is 22.6g
Please help me with showing the steps.
Thank you
Thank you
Those figures on heat are a bit misleading.
I think some of them refer to the number of Joules to change 1 kilogram by 1 degree, while others refer to how many Joules are needed to melt/vaporise on 1 gram of material.
What temperature did the ice start at?
Did you allow for the fact that once the steam condenses, it then has to cool from 100 to 0.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
