Calculate the resistance, then find the current at the new voltage
To calculate the cost of running a 78.9 W light bulb at a reduced voltage of 59.2 V, first determine the resistance using the formula R = V^2 / P, which gives a resistance of approximately 146.5 ohms. Next, find the current at the new voltage using I = V / R, resulting in a current of about 0.404 A. The power consumed at 59.2 V can then be calculated as P = VI, yielding approximately 24.1 W. Finally, to find the monthly cost, use the formula for energy cost, which results in approximately 35.29 cents for 30 days. The initial calculation was incorrect due to not adjusting the power consumption for the lower voltage.
srhly
A 78.9 W, 107.3 V light bulb is plugged into a 59.2 V outlet. If energy costs 4.9 cents/kW*h, how much does it cost per month (30 days) to leave the light bulb turned on? Answer in units of cents.
This is what I did:
(78.9W/107.3V)(59.2V)(24hours)(30days)(4.9cents/kW*h)(1kW/1000W)
I got 153.58 cents. I know the answer is incorrect, but where did I go wrong?
P=VI
V=IR
Calculate the resistance, then find the current at the new voltage. Then use conversion factors to get your price.
Thanks, that helped!
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
