Calculate the velocity of the centre of mass at threshold
unscientific
A high-energy photon γ1 of energy 261 GeV collides with an infrared photon γ2 of energy 1eV to produce an electron-positron pair via the reaction
γ1 + γ2 → e- + e+
Conservation of momentum:
p1 - p2 = (0.5)pe
But since p1 is 1011 times more than p2,
pe ≈ (0.5)(p1) = 6.96 x 10-17 kg m s-1
But when i try to calculate the velocity of the positron/electron using the momentum i get v = c...
Comparing orders of magnitude
pe ≈ 10-17
m(γv) = (10-23) (γ)
This implies that γ ≈ 106...
Am I doing something wrong here?
First, working in SI units is a bit impractical here - you get large powers of 10 everywhere.
Second: How can you know that the reaction is at threshold? Otherwise p1 - p2 = (0.5)pe is wrong.
You should get something really close to, but below c.
The order of magnitude is correct.
I tried to calculate it but my calculator simply gives c...
##\frac{v-c}{c} \approx 5 \cdot 10^{-13}##, you would need ~13 digits to see a difference.
Is this question a trick question?
No, why?
What is the problem statement, by the way? What are you supposed to calculate?
mfb said:
No, why?
It's a 7 marks question, where I'm supposed to find the velocity of the positron/electron pair at threshold energy.
Well, you can give the relative deviation from c as result (similar to my post), as the value in m/s is not really interesting.
I see, so this is actually an approximation question?
I don't understand your question. You can give an exact result, where is the problem?
The problem is that my calculator's only able to calculate up to 8 decimal places.. so it can only give 0.99999999c anything beyond that it automatically registers c.
You can calculate (v-c)/c with a precision of 8 decimal places then.
Here's what I got; 12 decimal places. When i substituted it into my calculator it gave me a value for gamma as 7*10^5
##\beta = \sqrt{1-10^{-12}} \approx 1-\frac{1}{2}10^{-12}##
##1-\beta \approx 5 \cdot 10^{-13}##
This allows to determine (1-β) with the same relative precision as γ.
