Calc Work: F<y,x,z^3> from P(1,1,1) to Q(2,3,4)
  • Thread starter PsychonautQQ
  • Tags
    Work
In summary, to calculate the work performed by the force field F = <y,x,z^3> from P = (1,1,1) to Q = (2,3,4), you can use the potential difference between the two points, which is obtained by calculating the potential function f = xy + (z^4)/4 and finding the difference between the values at the two points. This yields a work value of 68.75.
PsychonautQQ
784
Calculate the work performed by the force field F = <y,x,z^3> from P = (1,1,1) to Q = (2,3,4).
So first I found that F must be a conservative field because ∇(xy + (z^4)/r) = <y,x,z^3>
Since it is a conservative field it is path independent... which means something that my teacher would be mad at me for not knowing (lol)
Can I parameterize the line integral in terms of t?
like
c(t) = <1+t,1+2t,1+3t>
c'(t) = <1,2,3>
∫F dot c'(t) dt = W? then what would be the bounds on my integral?
Since you've found the potential function, why not just take the potential difference?
^what he or she said. Which is, coincidentally, a very useful result of path independence!
c'(t) = <1,2,3>
What values of ##t## correspond to the two points?
0 and 1?
so ∫F dot c'(t) dt = W between 0 and 1 will give me the correct answer?
how do I put F into terms of t though? like x = cos(t) y = sin(t) and z=z? ;-( I'm confused
PsychonautQQ said:
0 and 1?
Why do you answer every hint with another question? Aren't you capable of plugging ##t=0## and ##t=1## into your equation of the line and checking whether you get the two points yourself?
Yes, if you insist on doing the problem the hard way. Had you heeded the advice in post #2 you would have been done with this thread long ago.
Likes 1 person
I got the work = 68.75.
f(r(Q) - f(r(P)
f = xy + (z^4)/4
from <1,1,1> to <2,3,4>
so
(2)(3) + ((4)^4)/4 - ((1)(1) + ((1)^4)/4
70 - 1.25
68.75
Is this the correct method for doing this problem?
f(r(Q) - f(r(P)
f = xy + (z^4)/4
so
70 - 1.25
68.75
Yes. (Btw, you wrote /r instead of /4 in the OP. Adjacent keys, I see.)
Likes 1 person
1. What is the formula for calculating work in a vector field?
The formula for calculating work in a vector field is W = ∫F⋅dr, where W is work, F is the vector field, and dr is the differential displacement vector.
2. How do I find the vector field in this problem?
In this problem, the vector field is given as F. This means that at any given point in the field, the vector F has components of y, x, and z^3 in the y, x, and z directions, respectively.
3. What are the coordinates of the starting and ending points in this problem?
The starting point in this problem is P(1,1,1), which means that the initial coordinates are x = 1, y = 1, and z = 1. The ending point is Q(2,3,4), which means that the final coordinates are x = 2, y = 3, and z = 4.
4. How do I calculate the differential displacement vector in this problem?
The differential displacement vector, dr, is calculated by taking the difference between the final and initial coordinates. In this problem, dr = (2-1, 3-1, 4-1) = (1, 2, 3).
5. What is the final result of the calculation?
The final result of the calculation is the value of W, which represents the work done by the vector field from P to Q. It is important to note that this value may be positive, negative, or zero depending on the direction of the vector field and the displacement vector.
