SniffLimit
- 2
- 1
<edit: moved to homework. No template in the post.>
An ice maker inputs liquid water at 25 degrees C and outputs ice at -5 degrees C. Assume there is 1 kg of water and the volume does not change.
Cp liquid 4.18 kJ/kg-K
Cp solid 2.11 kJ/kg-K
∆H fusion 334 kJ/kg
I need to calculate:
I've already calculated the water's entropy change as -1.628 kJ/K. Where would I go from here, for the second question? Would work be the difference between Qhot and Qcold, where Q is the change in entropy times the temperature in K?
I've calculated the coefficient of performance (COP) to be 8.9383333 (or is it 0.100620493?), but I'm unsure of how to use that to find the work.
Any help will be greatly appreciated.
∆H fusion 334 kJ/kg
- Entropy change of the water, in kJ/K
- Minimum electrical work required, in kJ
- Allowing the ice to thaw and return to room temperature, what is the universe's change in entropy for the cycle, in kJ/K?
- What about if the ice maker has an efficiency of 20%?
