Calculating Acceleration for a Monkey Lifting a Crate | Force and Motion
  • Thread starter Thread starter pinkxoxo
    Force Motion
The discussion focuses on calculating the acceleration required for a 9 kg monkey to lift a 21 kg crate using a massless rope over a frictionless tree limb. The least acceleration needed for the monkey to lift the crate off the ground is determined using Newton's second law, F=ma. The correct acceleration is found to be approximately 22.876 m/s², but the user initially miscalculated this value. The tension in the rope must also be calculated to fully understand the forces at play in this scenario.
  • Newton's Second Law of Motion (F=ma)
  • Understanding of gravitational force (9.8 m/s²)
  • Basic principles of tension in ropes
  • Concept of frictionless systems
  • Calculate the tension in the rope when the monkey is lifting the crate.
  • Explore the effects of different masses on acceleration in similar systems.
  • Learn about frictionless pulley systems and their applications.
  • Study the dynamics of forces in vertical motion scenarios.
Physics students, educators, and anyone interested in understanding the dynamics of force and motion in real-world applications.
pinkxoxo
1. THE PROBLEM: A 9 kg monkey climbs up a massless rope that runs over a frictionless tree limb and back down to a 21 kg package on the ground (Fig. 5-54).
Figure 5-54.
(a) What is the magnitude of the least acceleration the monkey must have in order to lift the package off the ground?
m/s2
Assume that after the package has been lifted, the monkey stops its climb and holds onto the rope.
(b) What is the monkey's acceleration?
m/s2
(c) What is the tension in the rope?
N
2.) MY ATTEMPTS: I figured that in order for the monkey to be able to lift the crate its acceleration should be proportional to where the monkey and crate had the same force.
F=ma=m(Monkey(9))(a)=m(Crate(21))(9.8)
a=22.876 m/s^2...according to web assign I am wrong! I can solve the other parts of the problem if I knew how to find the first acceleration
PLEASE HELP :)
(a) To start, I would calculate what the rope tension must be in order to just start lifting the package.
How would i calculate that? F=ma but the only a i see given is gravity?
Well, to put it another way: what would be the force required to lift anything off of the ground?
F = ma is key. And there IS another a apart from gravity. Hmmm, what could be accelerating in the problem?
  • · Replies 38 ·
  • · Replies 128 ·
11K
