Calculating Car Acceleration on a 3% Slope at 88.5 km/h
  • Thread starter Thread starter Apprentice123
    Car Dynamic
In the discussion about calculating car acceleration on a 3% slope at 88.5 km/h, participants clarify that if a car is moving at a constant speed, the acceleration is zero due to Newton's second law, indicating that the net force is also zero. The conversation highlights the importance of understanding forces acting on the car, specifically the balance between the engine's forward force and the backward force due to weight. There is confusion regarding the calculation methods, particularly in using velocity to derive acceleration, which is deemed incorrect. Participants emphasize that proper understanding of the problem and correct application of physics principles are essential for solving such exercises. The discussion ultimately revolves around the correct interpretation of forces and acceleration in the context of constant speed on an incline.
Apprentice123
A car is rising an excerpt in slope of 2%, at a constant speed of 88,5 km/h.
If the driver does not change the motion, or changing the pressure of your foot on the accelerator, which should be the acceleration of the car down the stretch of 3%?Answer
0,491 m/s^2
Apprentice123 said:
A car is rising an excerpt in slope of 2%, at a constant speed of 80,5 km/h.
Answer
0,491 m/s^2
People can't help you unless you post your attempted solutions. It's a place where people help you on homework, not do your homework for you.
I'm not asking you to resolve. I would like an explanation of the exercise
It is:
I have a triangle of sides 2 and 100. Find the angle with the floor.
theta = 1,145
velocity x sin(theta) = 24,58 x sin(1,145) = 0,4911 m/s^2.
correct ? I did not use the slope of 3%
Your value for the angle of the incline (on the upward slope) is correct (edit: in degrees).
Your velocity in m/s looks wrong.
Your method also looks wrong. It makes no sense to get an acceleration by multiplying a velocity by a dimensionless number. Do you understand why this is wrong? vsin(theta) is meaningless here.
Hi Apprentice123! :smile:
Hint: on the upslope, the acceleration is zero …
so what is the force per mass? :wink:
If the driver is moving at a constant speed, then a = 0. By Newton's second law, the net force on the car is zero. This means that
magnitude of forward force due to engine = magnitude of backward force due to weight. Therefore:
STEP 1: You can figure out how much force the engine is providing to drive the car upward.
Here, forward and backward are directions along the incline.
On the way down, the driver doesn't change the gas applied. Therefore, the force due to the engine is the same. This is the key to solving the problem.
I edited the speed (was wrong in the order of exercise).
Sorry, I do not understand English very well.
Are you saying that:
Psin(theta) = m.a ?
I find a = 0,294 m/s^2
Apprentice123 said:
Psin(theta) = m.a ?
Sorry, I don't know what P is.
Component of weight parallel to plane = ma
EDIT: I don't get the same answer as you.
