Calculating Charge Transfer in Silver Spheres Using Coulomb's Law
The discussion focuses on calculating the charge transfer between two silver spheres using Coulomb's Law. The problem involves determining the fraction of electrons that must be transferred to create a specified attractive force. Participants clarify that the charges on the spheres are equal and opposite, and emphasize the need to correctly calculate the total charge per sphere. The calculations involve using the number of electrons per silver atom and the total number of atoms in the spheres to find the fraction of electrons transferred. Ultimately, the original poster resolves their confusion by correcting a calculation error, reinforcing their understanding of Coulomb's Law.
notmetalenough
I'm having trouble even beginning this problem. I'm not quite sure how to convert from the charge, which I believe I can find, to the number of electrons shared. If someone could help me understand what I'm being asked to find, and how to find it, I would really appreciate it. The problem is as follows
Two small silver spheres, each with a mass of 9.0 g, are separated by 0.60 m . Calculate the fraction of the electrons in one sphere that must be transferred to the other to produce an attractive force of 2*10^4 (about 2 tons) between the spheres. (The number of electrons per atom of silver is 47, and the number of atoms per gram is Avogadro's number divided by the molar mass of silver, 107.87 g/mol.)
I have a few questions about this, am I to assume that the charges are equal? If they are not, how would I find them?
for coulomb's law, I figure that if F = (8.99*10^9) * (q_1 * q_2)/r^2, that q_1 * q_2 = 1.802 * 10 ^-6 or a total charge of about 80 microCoulombs. So the number of electrons being shared (since the charge of 1 e = 1.60*10^-19), would be about 5.0 * 10 ^ 12.
So if there are 47 electrons per silver atom, and 9 grams at 107.87 g/mol, then there should be about (6.02 * 10^ 23) / 107.87 atoms in a gram, * 9 grams, * 47 electrons. so about 2.36*10 ^ 24 electrons in one sphere.
if I take the number of electrons being shared and divide it by the number of electrons total, I get about 2.12 * 10 ^ -12 as the fraction of electrons being shared.
Which apparently is wrong. Where do I need to start over?
Sure the charges are equal (and opposite). You are taking electrons from one sphere and putting them on the other. The total charge (the sum of both spheres) must still be zero.
Recheck your answer for the charge per sphere. You need to solve for q.
This part looks OK.
That was the problem. I just took the square root of the number I got (which was typoed in what you read) and continued with the problem to get the correct answer. At least I found that my concept of the problem wasn't what was flawed. Makes me feel better about my understanding of coulomb's law.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
