Calculating Combined Mass Motion of Two Cars
The discussion revolves around calculating the center of mass velocity of two cars, Car A and Car B, with masses of 2400 kg and 1100 kg, moving at speeds of 45 mph and 65 mph, respectively. The formula used for the calculation is Xcm = (M1X1 + M2X2) / (M1 + M2). The calculated center of mass speed is 51.3 mph, which raises doubts about the simplicity of the solution. However, it is emphasized that straightforward problems are common in homework, and understanding the material can lead to seemingly easy answers. Confidence in the method used is encouraged, as it aligns with the principles of physics.
linnus
Car A with mass 2400 kg is moving along a straight stretch of road at 45 miles per hour. Car B with mass 1100kg follows with speed 65 miles per hour. How fast is the center of mass of the 2 cars moving?
Xcm=(M1X1+...+MnXn)/ (M1+...+Mn)
hmm i did
(2400kg x 45mph +1100kg x 65 mph)/ (1100kg+2400kg)= 51.3 mph
But that seems a bit too easy..
May seem too easy, but that's no reason to mistrust it.
hmm so was my method right?
Homework questions aren't meant to be a trick! If you've studied, and understand the material, then often you will find the problems quite straightforward.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
