Calculating Composite Center of Gravity -- Boat Rack for my Truck
The discussion focuses on calculating the composite Center of Gravity (COG) for a boat and dolly setup on a truck rack. The user seeks to ensure that 75% of the boat's weight is on the rear axle, questioning whether the COG should be positioned 25% of the wheelbase ahead of the rear axle. Experts clarify that calculating COG involves understanding torque and balance, stating that the user's initial approach oversimplifies the situation. They emphasize the importance of using the correct equations for torque and moment to find the composite COG accurately. The conversation concludes with a confirmation that the user's calculations align with the principles of physics when properly applied.
RLewis42
Hi, I'm new here, great forum!
I am building a boat rack for the top of my truck for a particular boat and boat dolly. The boat will be upside down with the beach dolly attached. It is a side loader, so balance is critical. I need to calculate the combined Center Of Gravity (COG) of the boat and dolly before I will have them together to be able to measure it with a hoist. I have come up with a common sense equation for this, but sometimes in physics things that you think are simple and linear are not. Thanks for any information. I don't know if it is the correct term, but I am using COG as the balance point of an object when the fulcrum is placed below the object.
First, I have a rudimentary question about COG that may seem ridiculous, but this is not my field and I do not assume I know anything until I know it.
If I want 75% of the boat weight to be on the rear axle, do I place the Boat COG 25% of the wheelbase(C) ahead of the rear axle?
Now for the composite part. Two objects A and B are stacked and I need to calculate the combined COG of the stack. Obviously, the combined COG will fall somewhere between the two object COGs. Can I calculate the distance (x) that the combined COG moves away from the Object A COG as (Y)*(MassB/MassA) ? In this example it would be Y/4.
No. You need the torques to balance - so if X is the moment arm for object A, then Y-X is the moment arm for object B.
Similar for the first question - you need the force on the rear axle due to the torque about the front axle to be 1/4 of the overall weight.
Simon,
Thanks very much for helping.
I am not sure where to go from here. Let's look at the two examples separately.
1. Placing Boat on Trailer: Let's say I have taken a 2" wide sling around the bottom of the 14' boat and hoisted upward to determine the point on the boat where it balances. I have been calling this COG. If I want 75% of the weight of the boat on the rear axle, the trailer wheelbase is 10'. Are you saying it is not as simple as moving the boat COG 2.5' ahead of the rear axle? Is it close? What else could I do?
2. Composite COGs: You say that my simple attempt to calculate the new COG ignores torque. Do you mean that the approximate new COG cannot be determined with the given data? For example, are you saying that when the top object A's fulcrum is moved downward under object B that the original COG of object A is useless information and cannot help determine the new composite COG?
thanks,
That is correct - something you can verfy by building a small model and experimenting.
Is it close?
Define "close".
You could work out the center of gravity correctly ;)
Did I? I didn't mean to.
The objects have a lot of symmetry so finding the balance point will find you the axial location of the COG - you don't care how high the point is off the axis so that should be fine for your purposes. The "balance point" automatically accounts for the torques - I am saying that your approach to finding the composite COG is incorrect - you need to modify it as I have said to.
No.
I mean that it's your boat/trailer and if you don't want to pay an engineer you'll just have to learn to do it yourself.
If you have mass A and mass B separated by a distance y, then the COG will be at distance x from mass B that satisfies the relation:
##\qquad## mA(y-x)=mBx
... solve for x.
Do you not know how to calculate COG and moments?
Likes RLewis42
Thanks Simon for your help and patience.
1. Composite COGs:
For Ma = 100 lbs, Mb = 25 lbs, y = 10, I see the equation you suggest, mA(y-x)=mBx, gives a significantly different answer (8) than my proposed formula: (Y)*(MassB/MassA) which gives (7.5).
Thanks for that correction.
2. Placing Boat on Trailer:
Below, I have tried to adapt some moment COG equations to my problem.
Example: W = 300 lbs S = 8' want to find s1 and s2 for 75% of W on rear axle:
R1 * s1 = R2 * s2
R1 = .75 * 300 = 225
R2 = .25 * 300 = 75
225 * s1 = 75 * s2
s1 = 75/225 * s2 = .333 * s2
s1 + s2 = 8'
(.333 * s2) + s2 = 8'
s2 * (.333 + 1) = 8'
s2 * 1.333 = 8'
s2 = 6 s1 = 2
Is this correct? What puzzles me is that it the same answer as given by my intuitive "Bubba Science" formula:
s2 = S * (% of W you want on rear axle)
thanks for any clarification,
Everything above is right (except mA(y-x)=mBx should read mB(y-x)=mAx according to the drawing) but here's a more direct approach:
The summation of moment (a.k.a. torque) about any point should be equal to zero. Since we can use any point of reference, we can choose the point where the front reaction force is applied. This will eliminate this force as its moment about this point is zero (no lever arm). So the other two moments will have to balance out:
W * S2 = R1 * S
Or:
R1 / W = S2 / S
And because R1 / W is the %W on the rear axle by definition, then S2 / S represent the same value.
Then you can simply find the other values by substraction, i.e. S1 = S - S2 and R2 = W - R1.
Composite COG
For the composite COG, you can use a similar thinking. You choose the point of reference to be acting at one of the mass COG, say mA. Then, all that is left are the reaction moment of the total weight and the one from WB = mBg. So:
(mA + mB)g * x = mBg * y
g can be eliminated:
(mA + mB) * x = mB * y ----------> note that it is the same as mB(y-x)=mAx
Or:
x = mB / (mA + mB) * y
x = mB / mtotal * y
Likes RLewis42
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
