Calculating Constant speed of an Elevator Rising
To calculate the constant speed of an elevator with a motor power of 14 kW and a mass of 1100 kg, the relevant equations include gravitational potential energy (mgh) and kinetic energy (1/2 mv^2). The power produced by the motor can be equated to the work done per second, which is 14 kJ. To find the speed, one must determine how much height can be gained per second using the power output. The discussion highlights a need for algebraic manipulation to connect power, mass, and speed effectively. The key takeaway is that sufficient information is available, but proper application of physics principles is necessary for the solution.
Millacol88
The motor for an elevator can produce 14kW of power. The elevator has a mass of 1100 kg, including its contents. At what constant speed will the elevator rise?
I'm not really sure. Probably Gravitational potential = mgh. Kinetic energy = 1/2mv^2 because its looking for speed.
I'm really not sure. It doesn't seem like enough information is given to solve for anything. There's probably some algebraic manipulation I'm missing.
Consider work done per second (14 kJ) - what increase in height does that correspond to (14kJ = mgh)?
-S
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
