Calculating Detection Distance of Superconducting Gravity Meter
  • Thread starter Thread starter Gammage
    Gravity Meter
To calculate the detection distance of a superconducting gravity meter in relation to a 78 kg person, one must understand that the meter measures changes in the gravitational field, not just gravitational force. The relevant equation is g = G(M)/r^2, where g is the change in gravitational acceleration, G is the gravitational constant, and M is the mass of the person. The goal is to determine the distance at which the gravitational acceleration due to the person equals 1×10^-11 m/s². The initial approach using the gravitational force equation was incorrect, as it does not account for the gravitational field's dependence on distance. Correctly applying the gravitational field equation will yield the necessary distance for detection.
Gammage
A superconducting gravity meter can measure changes in gravity of the order = 1×10-11 (delta g)/g. You are hiding behind a tree holding the meter, and your 78 kg friend approaches the tree from the other side. How close to you can your friend get before the meter detects a change in g due to his presence?
Answer in units of m.
I know that Fgrav = G (m1m2)/r^2 and G = 6.672e-11 Nm^2/kg^2
My first thought was to assume the m2 was 1kg and set the Fgrav = 1e-11 N, but this was wrong.
You are using the equation that describes the force between two objects due to gravity. What a gravity meter detects is variance in the gravitational field. What physics do you know of the gravitational field?
Very Little
I don't think we have discussed yet in class, let me check the book for any references. This is a first year Mechanics course for natural science majors.
Hmm, there is a very brief explanation in the chapter we are in showing that the field is equal to G(M)/r^2, which is simular to what i did before but this would give me N/kg, do i factor his mass in again to get some cancelations?
The gravitational field is basically the acceleration due to gravity and is given by
g =G\frac{M}{r^2}
where M is the mass of the Earth. In this question you will essentially need to work out how far away the 78kg (i.e. use his mass instead of the Earths) guy has to be to have an acceleration toward him due to his own gravity of 1x10-11 ms-2.
the 1x10^-11 is mentioned in the problem as delta g divided by g. when I set g = 1x10^-11 and M = 78kg, and solved for r the answer is wrong.
