Calculating EDTA Titration Volume for CoSO4 Solution
To calculate the volume of 0.08640 M EDTA needed to titrate a 25 mL aliquot of a CoSO4 solution containing 1.694 mg/mL, first determine the moles of CoSO4 in the aliquot, which is approximately 2.73 x 10^-4 moles. The titration is assumed to follow a 1:1 molar ratio between EDTA and CoSO4, meaning one mole of EDTA will react with one mole of CoSO4. To find the required volume of EDTA, multiply the moles of CoSO4 by the concentration of the EDTA solution. Additionally, consider that pH control may be necessary, and consulting alternative resources or a teacher could provide further clarity on the molar ratios involved. Understanding that EDTA acts as a chelator, coordinating with metal ions, is crucial for accurate calculations.
LakeMountD
A solution contains 1.694mg of CoSO4 (155.0 g/mol) per mL. Calculate the volume of 0.08640 M EDTA needed to titrate a 25 mL aliquot of this solution.
Not really sure, the book is no help but this may help:
K(CoSO4) = [CoSO4] / ([CO2+] [SO42-])
K'CoSO4 = alpha4 * KCoSO4
My book is absolutely horrible which is why I had to come to the forums for help but I am assuming I find the mol. of CoSO4, which was 2.73 x 10^-4 then assume that [CoSO4] ~= 4.37x10^-4
I think you use K'CoSO4 = alpha4 * KCoSO4, but again I can't figure it out :(
Okay I think I might have figured it out. Get moles of CoSO4, then multiply that by the molar ratio of EDTA to CoSO4 then multiply by the concentration of EDTA?
Superficially, best guess is that this should be a fairly uncomplicated 1 to 1 mole titration of the EDTA specie to the Co specie. If that "alpha" stuff is important in the exercise, then the superficial idea is not enough, and that some pH control might be needed. If you have the time, check an alternative quantitative book and ask your teacher.
Yeah that is the problem I am having. How do I know what the molar ratio of EDTA to any metal is? The book doesn't explain it in the examples, it just throws the ratio in there. It gives a 1:1 ratio to EDTA:Mg(NO2)2 but not sure about the others.
Thanks.
How do I know 1:1 ? Habit! Not remember exactly how. Just assume 1:1 mole ratio. The EDTA is not just a ligand; it is a CHELATOR. One EDTA will coordinate bond with one metal ion. (mole-wise, that is)
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
