Calculating Electric Field Energy
To calculate Electric Field Energy in the context of a classical hydrogen atom, one must first determine the electric field using Gauss' Law, assuming the electron and proton are uniformly charged spheres. The problem involves calculating various forces and energies related to the atom, including electrical and gravitational forces, as well as the velocity of the electron. After finding the energy density, which is crucial for determining the total electric field energy, the next step is to apply this knowledge to the specific dimensions given (1.00E-15 radius for both particles). Understanding the relationship between electric field and energy density is key to solving the problem. The discussion emphasizes the importance of clearly defining the problem and utilizing relevant physics principles to reach a solution.
bertholf07
Does anyone know how to calculate Electric Field Energy?
bertholf07,
It is generally best to post the entire problem you're having trouble with, followed by your thoughts or attempts at a solution, followed by any specific questions you have.
- Warren
Ok we are given that it deals with the classical hydrogen atom and it has a single electron fixed in orbit aroudn the proton with the bohr radius which is 5.29E-11m. We were told to find the Electrical Force, The Gravitational Force, The ratio of those forces, The velocity of the electron, The electrical potential arising from the proton, The electrical potential energy, and the total mechanical and electrical energy. I found all these with no problems but than it goes on to say "An improvement of this classical mechanical model of the atom involves the energy density of the electric field in a region of space. Find the total electric field energy for the electon and proton assuming that each one has a radius of 1.00E-15" That is where I don't know what to do I know how to find the energy density but that is not what he is asking. Do I need to find the electric field or what?
Yes, you need to find the electric field. It looks like you are asked to assume that the electron and proton are uniformly charged spheres, and required to calculate the electric fields using Gauss' Law and superposition. The energy density at a point can be calculated from the field there. I'm sure your text has a section on the energy density.
Yes it does that a section on energy density I have read over it a few times just could not figure it out. I believe I will be able to figure it out from there Thanks Alot
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
