Calculating Electric Field from Two Point Charges
The discussion revolves around calculating the electric field at a point due to two point charges: a positive charge of 3*10^-6 C at the origin and a negative charge of -4*10^-6 C located 0.1 m along the x-axis. The user calculated the electric fields from each charge at a point 0.15 m along the y-axis, resulting in a combined magnitude of 88808 N/C. However, feedback indicates that the user may have incorrectly added the magnitudes instead of using vector addition for the electric fields. The conversation emphasizes the importance of considering directional components in electric field calculations.
infected
"A point charge of 3*10^-6 C is at the origin and another point charge of -4*10^06 C is at point 0.1m away along the x axis.
What is the magnitude and direction of the electric field at point 0.15m from the origin along the posting y-axis?
E= Q/(4PIε°*r^2)
ε°=8.85*10^-12
Electric Field from the first charge to the point on the Y axis:
E1 = (3*10^-6)/(4PIε°*0.15^2)
Electric Field from the Second charge to the point on the Y axis:
E2 = (-4*10^-6)/(4PIε°*0.18^2)
Magnitude Of Electric Field = E1+E2=88808N/C
Direction is 158 Degrees from the X(got this from the vectors)
This is my answer, my physics is really rusty and I have a gut feeling I've gone completely wrong. A checking and assistance would be appreciated.
Thanks.
welcome to pf!
hi infected! welcome to pf! :smile:
(have a pi: π and try using the X2 and X2 buttons just above the Reply box :wink:
(you mean the positive y-axis?)
your E1 and E2 magnitudes look ok :smile:
but i think you've added the magnitudes, instead of using vector addition (ie adding the coordinates separately, or using a vector triangle) :wink:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
