Calculating Fgrav at a non-point mass
  • Thread starter Thread starter diminion
    Mass
The discussion focuses on calculating gravitational force (Fgrav) at a non-point mass using a systematic approach outlined by a professor. The key steps include drawing a diagram, selecting a small mass element, and integrating the force components. A critical point raised is the understanding of symmetry, which explains why the vertical components of force (Fy) cancel out, resulting in Fy being zero. The participant seeks clarification on using trigonometric functions for the calculations and confirms that symmetry simplifies the process. The conversation emphasizes the importance of recognizing symmetrical properties in gravitational calculations.
diminion
Hello! I signed up about week ago, in case i needed some help in physics, and today i do. I Hope someone can explain this to me a little better.
Anyways, yesterday we started the chapter on gravitation. Our professor layed out eight steps we should follow to calculate the Fgrav at a non-point mass. They were,
1. Draw a diagram
2. Pick a small chunk (dm)
3. Draw a line from dm to the 2nd mass
4. Draw a force vector starting at the 2nd mass
5. Calculate dF created between dm and the 2nd mass
6. Check symmetry
7. Calculate remaining components of dF
8. Integrate
He gave us the following:
dF\ =\ G\frac{dm M_{2}}{r^{2}}
Which he broke down into components,
dF_{x}\ =\ G\frac{dm M_{2}}{r^{2}}cos\theta
and
F_{y}\ =\ 0 by symmetry.
When i went home, i proceeded to find dFx
dm\ =\lambda dl
\lambda\ =\frac{M}{L}
r\ =\sqrt{(R^{2}+l^{2})}
cos\theta\ =\frac{R}{\sqrt{(R^{2}+l^{2})}}
dF_{x}\ =\ G\frac{\lambda dl M_{2}}{(R^{2}+l^{2})}\frac{R}{\sqrt{(R^{2}+l^{2})}}
F_{x}\ = \int dF_{x}\ =2\int^{\frac{L}{2}}_{0} \ G\frac{\lambda dl M_{2}}{(R^{2}+l^{2})}\frac{R}{\sqrt{(R^{2}+l^{2})}}
F_{x}\ = 2 \ G\lambda M_{2}R\int^{\frac{L}{2}}_{0}\frac{dl} {(R^{2}+l^{2})^{\frac{3}{2}}}
Now to finish this up, it seems to me like trig substitution. Is that the correct way to proceed with he integral?
My main question that i don't understand is, What does he mean "by symmetry"? I first assumed he was going to use sin\theta for Fy but he didnt. Why is Fy=0?
Thanks for any help you can give me about the symmetry part.
Since M2 is symmetrically located with respect to your extended mass, the y-components of force from the upper half will be exactly equal and opposite to the y-components from the lower half. Thus, "by symmetry", you know they will cancel out. Of course you can certainly work it out using sinθ, but you'll get the same answer.
Oh, i see that. Thanks for that clarification!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
